DFR0554
DFR0554
    DFROBOT
    16x2 RGB LCD 字符 显示 Gravity 平台评估扩展板
DFR0554 数据手册
Gravity: I2C 16x2 Arduino LCD with RGB Font Display SKU: DFR0554 Contents • • • • • • 1 Introduction 2 Specification 3 Board Overview 4 Tutorial o 4.1 Requirements o 4.2 Connection Diagram o 4.3 Sample Code o 4.4 Expected Results 5 FAQ 6 More Documents Introduction Gravity: I2C 16x2 Arduino LCD with RGB Font Display SKU: DFR0554 Accustomed to the same LCD screen, do you want to have a different experience? DFRobot LCD1602 will bring you a new visual feeling, It is not the same as the previous LCD monochrome screen, supports RGB full-color font, can provide 16 million kinds of color combinations. DFRobot Gravity I2C 16x2 Arduino LCD with RGB Font Display use universal Gravity I2C interface, it means only two communication lines, you can realize communication and backlight control. The LCD screen can display 2x16 characters, support screen scrolling, cursor movement and other functions. Through dedicated Arduino library, you can complete all the design without cumbersome wiring and complex code. Specification • • • • • • • • Operating Voltage: 3.3V~5.0V Operating Current: ≤60mA Display Description: 16*2 Communication Mode: IIC/I2C Backlight: RGB can adjust backlight OperatingTemperature: -20 to +70℃ Storage Temperature: -30 to +80℃ Dimension: 87.0*32.0*13.0mm/3.43*1.26*0.51in Board Overview Gravity: I2C 16x2 Arduino LCD with RGB Font Display Num Label Description 1 VCC Positive Pole 2 GND Negative Pole 3 SCL IIC Clock Line 4 SDA IIC Data Line Tutorial Follow the pin description to connect the hardware, and download the sample code to UNO, after upload is successful, you can see the LCD display and backlight gradient. Requirements • • • • Hardware DFRduino UNO R3 (or similar) x 1 Gravity: I/O Expansion x1 Sensor cable • • Software Arduino IDE, Click to Download Arduino IDE from Arduino® Connection Diagram Sample Code Click here to download DFRobot LCD Library(Github) How to install Libraries in Arduino IDE /*! * file SetColor.ino * brief SetColor. * * Copyright [DFRobot](http://www.dfrobot.com), 2016 * Copyright GNU Lesser General Public License * * version * date V1.0 2017-2-10 */ #include #include "DFRobot_LCD.h" int r,g,b; int t=0; DFRobot_LCD lcd(16,2); //16 characters and 2 lines of show void setup() { Serial.begin(9600); // initialize lcd.init(); } void loop() { r= (abs(sin(3.14*t/180)))*255; g= (abs(sin(3.14*(t+60)/180)))*255; b= (abs(sin(3.14*(t+120)/180)))*255; t=t+3; //get R,G,B value lcd.setRGB(r, g, b); //Set R,G,B Value lcd.setCursor(0,0); lcd.print("DFRobot"); lcd.setCursor(0,1); lcd.print("Gravity: RGB LCD"); //R:0-255 G:0-255 B:0-255 delay(1); } Expected Results LCD changes the font color. FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum. More Documents • • RGB LCD1602 Datasheet RGB LCD1602 Dimension https://www.dfrobot.com/wiki/index.php/Gravity:_I2C_16x2_Arduino_LCD_with_RGB_Font_Display_SKU:_DFR0554#More_Documents 7-16-18
DFR0554 价格&库存
很抱歉,暂时无法提供与“DFR0554”相匹配的价格&库存,您可以联系我们找货
DFR0554
  • 1+151.163001+19.65070
  • 3+133.430253+17.34550
库存:10
