DFR0563
DFR0563
    DFROBOT
    GRAVITY: I2C 3.7V LI BATTERY FUE
DFR0563 数据手册
      Gravity: 3.7V Li Battery Fuel Gauge SKU: DFR0563   Introduction 3.7V lithium batteries are commonly used in many projects. However, The remaining power and voltage of the lithium battery are highly nonlinear. We can only roughly judge whether the battery is full or almost empty according to its voltage. The Gravity 3.7V Lithium Battery Fuel Gauge employs Gravity I2C interface, ultra-low operating current, and real-time tracking of the relative state of charge (SOC) of the battery through Maxim's patented algorithm, eliminating the need for full-toempty relearning and offset accumulation errors. Plug and play to accurately measure the voltage and remaining power of the battery. The module also features as a low battery power alert interrupt function. When the battery power falls below specified threshold, the ALR pin generates a falling pulse to trigger the external interrupt of the controller. You will find it a great help to estimate the battery life by learning the power consumption of the system with this module. In the solar powered projects, it helps to record the status of the battery power change in a day or even months, which benefits to understand the power balance of charge and discharge of the solar system. Features      Maxim's patented algorithm, accurate voltage and remaining power readings of lithium battery No charge-discharge relearning process, no offset accumulation errors, plug and play Wide input voltage, compatible with 3.3V and 5V controllers Programmable low power alert interrupt threshold Battery reverse connection protection Specifications       Input Voltage (VCC): 3.3V~6.0V Battery Input Voltage (BAT IN): 2.5V~4.2V Battery Type(BAT IN): 3.7V Li-polymer/Li-ion battery Operating Current: 50 uA Interface: Gravity I2C (logic level: 0-3.3V) Dimension: 22.0mm*30.0mm Applications    Solar Weather Station, Street Light Lithium Battery Charger Robotics Board Overview Label Name  Description  +  VCC  Power VCC(3.3~6.0V)  ‐  GND  Power GND  C  SCL  I2C Clock Signal  D  SDA  I2C Data Signal  ALR  ALRT*  Low battery power alert interrupt (active  low)  BAT IN Battery input  3.7V lithium battery connection port        REV  BAT  Battery reverse Indicator  When the battery is reversed, the reverse  polarity protection circuit is activated and  REV BAT lights up.  Arduino Tutorial Requirements     Hardware DFRduino UNO R3 (or similar) x 1 DFRobot Gravity: 3.7V Li Battery Fuel Gauge x 1 Gravity-4P sensor wire (or Dupont wires) x 1    Software Arduino IDE (V1.0.x or V1.8.x), Click to Download Arduino IDE from Arduino® Download and install the DFRobot_MAX17043 Library. How to install the library? Connection Diagram Read Battery Voltage, Remaining Power and Set Low Power Interrupt Alert     Connect the module to the Arduino according to the connection diagram. The battery can be connected to the 2P terminal or JST-PH2.0 2P connector. These two connectors are connected internally in parallel. The I2C address is fixed to 0x36. Install DFRobot_MAX17043 library. Open Arduino IDE, upload the following sample code to the Arduino UNO. Open the serial monitor of the Arduino IDE and set the baud rate to 115200. The module prints the battery voltage, the percentage of remaining battery power, and the interrupt alert message through the serial port. /* * file DFRobot_MAX17043.ino * * connect gauge I2C interface with your board (please reference board compat ibility) * * Voltage, percentage will be printed via serial. * Use API to config alaram and sleep (please reference to the readme in lib) * * Copyright [DFRobot](http://www.dfrobot.com), 2016 * Copyright GNU Lesser General Public License * * version * date V1.0 2018-3-26 */ #include "DFRobot_MAX17043.h" #include "Wire.h" #ifdef __AVR__ #define ALR_PIN 2 #else #define ALR_PIN D2 #endif #define PRINT_INTERVAL 2000 #define BAT_PERCENTAGE 32 DFRobot_MAX17043 uint8_t gauge; intFlag = 0; void interruptCallBack() { intFlag = 1; } void setup() { Serial.begin(115200); while(!Serial); Serial.println(); Serial.println(); pinMode(ALR_PIN, INPUT_PULLUP); ; attachInterrupt(digitalPinToInterrupt(ALR_PIN), interruptCallBack, FALLING) //default alert is 32% while(gauge.begin() != 0) { Serial.println("gauge begin faild!"); delay(2000); } delay(2); Serial.println("gauge begin successful!"); //gauge.setInterrupt(BAT_PERCENTAGE); as 1% - 32% (integer) //use this to modify alert threshold } void loop() { static unsigned long lastMillis = 0; if((millis() - lastMillis) > PRINT_INTERVAL) { lastMillis = millis(); Serial.println(); Serial.print("voltage: "); Serial.print(gauge.readVoltage()); Serial.println(" mV"); Serial.print("precentage: "); Serial.print(gauge.readPercentage()); Serial.println(" %"); } if(intFlag == 1) { intFlag = 0; gauge.clearInterrupt(); Serial.println("Low power alert interrupt!"); //put your battery low power alert interrupt service routine here } } Results       Arduino prints the current voltage (voltage), remaining power (percentage), and interrupt alert (if any) information every 2 seconds. Battery low power interrupt alert ALR instructions: The default value of battery low power interrupt alert threshold is 32%. That is, when the remaining power is lower than 32%, a falling edge interrupt is generated on the ALR pin. The threshold BAT_PERCENTAGE can be set to any integer between 1-32 (corresponding to 1%-32%, respectively). This threshold can be set by the function setInterrupt(). When the battery's initial remaining power is higher than BAT_PERCENTAGE, the ALR pin is set high. If it falls below BAT_PERCENTAGE (due to discharge) , ALR is pulled to low. The controller is triggered to print ”Low power alert interrupt!”, and clear interrupt through clearInterrupt(), which causes ALR back to high immediately. When the battery's initial remaining power is below BAT_PERCENTAGE, ALR generates a interrupt at the beginning. After the battery remaining power grows higher than BAT_PERCENTAGE (due to charge) , another interrupt will be generated when the power again falls below BAT_PERCENTAGE (due to discharge). If the clearInterrupt() is not called after the interrupt is occurred, ALR remains low regardless of the battery remaining power. Raspberry Pi Tutorial Requirements     Hardware Raspberry Pi 3 Model B (or similar) x 1 DFRobot Gravity: 3.7V Li Battery Fuel Gauge x 1 Gravity 4P sensor wire (or Dupont wires) x 1    Software Download and install the DFRobot_MAX17043 RaspberryPi library RASPBIAN Connection Diagram Installation 1.Start the I2C interface of the Raspberry Pi. If it is already open, skip this step. Open Terminal, type the following command, and press Enter: pi@raspberrypi:~ $ sudo raspi-config Then use the up and down keys to select “5 Interfacing Options” -> “P5 I2C” and press Enter to confirm “YES”. Reboot the Raspberry Pi. 2.Installing Python libraries and git (networking required). If it is already installed, skip this step. In the Terminal, type the following commands, and press Enter: pi@raspberrypi:~ $ sudo apt-get update pi@raspberrypi:~ $ sudo apt-get install build-essential python-dev pythonsmbus git 3.Download the driver library and run it. In Terminal, type the following commands, and press Enter: pi@raspberrypi:~ $ git clone https://github.com/DFRobot/DFRobot_MAX17043.g it pi@raspberrypi:~ $ cd ~/DFRobot_MAX17043/RaspberryPi/python pi@raspberrypi:~/DFRobot_MAX17043/RaspberryPi/python $ python DFRobot_MAX1 7043.py Read Battery Voltage, Remaining Power and Set Low Power Interrupt Alert    Connect the module to the RaspberryPi according to the connection diagram. The battery can be connected to the 2P terminal or JST-PH2.0 2P connector. These two connectors are connected internally in parallel. The I2C address is fixed to 0x36. Install DFRobot_MAX17043 RaspberryPi library. In the Terminal, type in the following commands and press Enter to run the sample code: pi@raspberrypi:~/DFRobot_MAX17043/RaspberryPi/python $ cd readAndInt pi@raspberrypi:~/DFRobot_MAX17043/RaspbeeryPi/python/readAndInt $ python r eadAndInt.py Results       RaspberryPi prints the current voltage (voltage), remaining power (percentage), and interrupt alert information (if any) every 2 seconds. Battery low power interrupt alert ALR instructions: The default value of the battery low power interrupt alert threshold is 32%. That is, when the remaining power is lower than 32%, a falling edge interrupt is generated on the ALR pin. This threshold can be set to any integer between 1-32 (corresponding to 1%-32%, respectively) with the function setInterrupt(). When the battery's initial remaining power is higher than interrupt alert threshold, the ALR pin is set high. If it falls below the threshold (due to discharge) , the ALR pin is pulled to low. The controller is triggered to print ”Low power alert interrupt!”, and then clear interrupt through clearInterrupt(), which causes ALR back to high immediately. When the battery's initial remaining power is below interrupt alert threshold, the ALR pin will generate an interrupt at the beginning. After the battery remaining power grows higher than interrupt alert threshold (due to discharge) , another interrupt will be generated when the power again falls below the threshold (due to discharge). If the clearInterrupt() is not called after the interrupt is occurred, the ALR pin will remain low regardless of the statue of the battery. Application Examples  Apply Gravity: 3.7V Li Battery Fuel Gauge to Sunflower: Solar Power Manager 5V to build a solar power management system. The battery fuel gauge can be used to monitor the charging of the battery with a solar panel in real time during the day, and the power consumption of the system during the night. Users can write their own code to record or print battery voltage and remaining power data, which can be employed to evaluate the "power balance" of the solar system in a day or even several months. These datum helps users to determine whether the nominal power of the panel or lithium battery power is large enough to fully support the entire system during the day and night.  The low power interrupt alert of the fuel gauge and controllable 5V power supply of the solar power management module can be used to save power when the battery power is lower than a specified threshold. The ALR pin will send an interrupt signal to trigger the controller to turn off the 5V power supply. This shuts off the power supply of external modules connected to the solar power module, and thus saves power.       FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum.        https://www.dfrobot.com/wiki/index.php/Gravity:_3.7V_Li_Battery_Fuel_Gauge_SKU:_DFR0563#More_Documents 7‐18‐18
DFR0563 价格&库存
很抱歉,暂时无法提供与“DFR0563”相匹配的价格&库存,您可以联系我们找货
