Gravity: Digital Signal Isolator
SKU: DFR0565
Gravity: Digital Signal Isolator is capable of isolating I2C digital signal and providing isolated power
to the sensor module, effectively preventing mutual interference between the sensor modules. This
digital signal isolator can be used for multi-parameter water quality detection systems to prevent
water quality sensors from interfering with each other.
In many cases, interference sources are existing. For example, a running pump in a fish tank will
release signals into the water, which interferes the sensors in the fish tank. In this case, electrical
isolation is needed to ensure the stable operation of the sensors. Some sensors, such as pH
sensors and electrical conductivity sensors, which share the same power source and measure in the
same container, will interfere with each other and do not work properly. In order to ensure stable
operation of the sensor modules, it is necessary to isolate the signal and the power.
After the analog signal isolator, we launched this digital signal isolator which specifically isolates the
I2C digital signal. What's more, the on-board 5V isolation power chip can directly supply the sensor
module, without additional power. This product is designed specifically for DFRobot I2C connector
sensor or modules, plug and play, no welding. Connect it into your circuit to get electrical isolation,
and the code of sensor module in control board does not need to be modified, which is simple and
convenient.
1.Please pay attention to the operating current of your sensor or module, the maximum
output current from Module side is 150mA.
2.All pins on the Module side (isolation side) are isolated from all pins on the Controller
side (non-isolation side). Do not short-circuit them.
3.It is normal for the isolator generates heat while working.
Specification
Operating Voltage: 5.0V
Connector Type: PH2.0-4P
Interface Protocol:I2C(IIC)
Interface Signal Level: High 3.3V, Low 0V
Dimension: 42 * 32mm / 1.65 * 1.26 inch
Controller Side(Non-isolation Side)
Supply Voltage: 5.0 ± 0.15V
No-load Current: 15mA(TYP)
Module Side(Isolation Side)
Output Voltage: 5.0 ± 0.15V
Output Current: 150mA(MAX)
Board Overview
Num
Label
Description
1
Power Input VCC(5.0±0.15V)
2
Power Input GND
3
C
I2C SCL
4
D
I2C SDA
5
Isolation Power Output VCC(5.0±0.15V)
6
Isolation Power Output GND
7
C
Isolation I2C SCL
8
D
Isolation I2C SDA
Connector Overview
As shown in the figure below, this digital signal isolator has two connectors, one is on the left
and another is on the right.
The left connector named Module should be connected to the sensor or module.The right
connector named Controller should be connected to the I2C bus of the main control board.
Tutorial
This tutorial will use a I2C DAC module as an example to demonstrate how to connect this digital
signal isolator in the circuit,to electrically isolate the sensor or module.
Requirements
Hardware
DFRduino UNO R3 (or similar) x 1
I2C Sensor or Module(e.g.I2C DAC module) x1
Double PH2.0 4P Cable x1
Gravity-4P I2C/ UART Sensor Cable x1 (or several DuPont cables) x1
Gravity: Digital Siganl Isolator x1
Connection Diagram
As shown in the picture below, connect the I2C sensor or module to the Module Side of the isolation
module (use a dual-head PH2.0 cable, this cable is included with the product). Then connect the
Controller Side of the isolation module to the I2C bus of the Arduino board.
After the steps above, the electrical isolation of the DAC module has been completed.
The code of the sensor or module in the main control board is the original code, so you do not need
to be modified.
https://www.dfrobot.com/wiki/index.php/Gravity:_Digital_Signal_Isolator_SKU:_DFR0565 9‐11‐18
很抱歉,暂时无法提供与“DFR0565”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+199.493431+25.93350
- 3+176.023623+22.88250
