DFR0566
DFR0566
    DFROBOT
    STM32 I/O 扩展 接口 Raspberry Pi 平台评估扩展板
DFR0566 数据手册
IO Expansion HAT for Raspberry Pi 4B/3B+ SKU:DFR0566 Introduction This IO Expansion HAT from DFRobot is the perfect companion for your Raspberry Pi 4B/3B+! It leads out all of the IO ports on Raspberry Pi including digital port, analog port, PWM, IIC, UART, SPI, and IIS. Besides that, the HAT is totally compatible with DFRobot Gravity Series which frees users from complicated connection work, and enables them to just concentrate on their projects building. Raspberry Pi GPIO pins work with a maximum logic level of 3.3V. Besides the 3.3V power sensor and module, the product also supports: • Sensor and module with 5V power supply and 3.3V level • PWM external power supply (6~12V) • Controlling multiple servos Specification • Driver Maincontroller: STM32 • Operating Voltage: 5V • PWM External Power Supply: 6-12V • PWM Pin Voltage: 5V • Sensor Interface Power Supply: 3.3V • Communication Interface: 28 digital Ports, 4 groups of analog port, 3 groups of IIC port, 1 group of UART, 4 groups of 5V power interfaces, 1 group of SPI, 1 group of IIS port • Device Address: 0x10 • Outline Dimension: 65×56mm/2.56×2.20” Board Overview Silkscreen Label + + 3.3V Positive - - Negative ⊕ ⊕ Binding post connect to external power positive ㊀ ㊀ Binding post connect to external power negative Digital 0-27 Raspberry Pi GPIO0-GPIO27 PWM 0-3 PWM signal output pin 0-3 Analog 0-3 Analog signal input pin 0-3 IIC C IIC port clock line D IIC port data line T UART Transmit port R UART Receive port 5V 5V 5V positive GND GND Negative IIS SCK IIS serial clock line DIN IIS serial data input UART Description Silkscreen SPI Label Description LCK IIS L/R channel selection line BCK IIS system clock line MISO SPI data output line SS SPI enable pin SCLK SPI serial clock line MOSI SPI data input line Note: • The GPIO number in this board adopts BCM codes. • When the VP port is not power by external power, the voltage of PWM ⊕ is 5V. • When the VP port is powered by external power, the voltage of PWM ⊕ is equal to that of the VP external power (6-12V). Tutorial Port and Learning Guide • Digital Port: IO expansion board offers 28 groups (D0-D27) of digital ports that are led out via Raspberry Pi ports GPIO0~GPIO27 (BCM codes). GPIO Learning Guide. • Analog Port: IO expansion board has four groups of analog ports A0-A3. The board integrates on-board MCU STM32, and 12-bits ADC. The input voltage of analog sensor is 12-bit ADC. After the analog data is converted into digital data, it will be sent to Raspberry Pi via IIC commnucation. Download Example Program. • PWM Port: IO expansion board provides four groups of PWM ports. Connect the STM32 to PWM. Raspberry Pi will send data to STM32 via IIC to control. VP port can supply 612V external power to PWM port. When not powered, the voltage of PWM ⊕ is 3.3V. Download Example Program. • IIC Port: IO expansion board has 3 groups of IIC ports that are led out via Raspberry Pi GPIO2(SDA.1)and GPIO3(SCL.1)(BCM code). IIC Learning Guide. • IIS Port: there is 1 group of IIS port that is led out via Raspberry Pi GPIO ports: GIO21 (SCK), GPIO20(DIN), GPIO19(LCK), GPIO18(BCK). • SPI Port: IO expansion board leads out a group of SPI ports via its GPIO port (BCM code): GPIO10(MOSI)and GPIO9(MISO), GPIO11(SCLK), GPIO8(SS). SPI Learning Guide. Example This example domenstrates how to use the sensors of all ports on Raspberry Pi expansion board. • Hardware o Raspberry Pi Board x1 o IO Expansion HAT for Raspberry Pi x1 o HDMI Cable x1 o Display x1 o Keyboard and Mouse x1 IIC Usage Operation and Program Execution Introduction • Enable Raspberry Pi I2C interface. (Way to enable SPI is the same with IIC). Skip this step if it is already enabled. Open Terminal and input the following commands, press "Enter": sudo raspi-config Use the "Enter" key to select: [Interfacing Options] or ([Advanced Options])->[I2C]>[Yes]->[OK]->[Finish]: • Install Phython demo library and git, and make sure the network connection of Raspberry Pi is fine. Skip this step if these have been installed. Input the following commands into the terminal: sudo apt-get update sudo apt-get install build-essential python-dev python-smbus git • Download the driver library and run. Input the following commands into the terminal: cd ~ git clone https://github.com/DFRobot/DFRobot_RaspberryPi_Expansion_Board.git • Two ways to run the program after the library is installed: 1. Input command: 2. cd DFRobot_RaspberryPi_Expansion_Board/raspberry python demo_adc.py 3. Open Thonny Python IDE under Raspberry Pi system to check the downloaded file. IIC Usage Example IO expansion board has 3 groups of IIC ports that are led out via Raspberry Pi GPIO2( SDA.1)and GPIO3(SCL.1)(BCM code). Take SEN0303 VEML6075 UV sensor as a example, click to dowmload [DFRobot_VEML6075 Library file] (https://github.com/DFRobot/DFRobot_VEML6075 "DFRobot_VEML6075 Library file"), or input the following command into the terminal: cd ~ git clone https://github.com/DFRobot/DFRobot_VEML6075.git Run the DFRobot_VEML6075_demo. # -*- coding: utf-8 -*''' * * * * * * * * ''' file DFRobot_VEML6075_demo.py normal test for VEML6075 UVA index, UVB index and UV index will print on terminal Copyright [DFRobot](http://www.dfrobot.com), 2018 Copyright GNU Lesser General Public License version V1.0 date 2018-12-18 import time import sys sys.path.append("..") from DFRobot_VEML6075 import DFRobot_VEML6075 if __name__ == '__main__': VEML6075 = DFRobot_VEML6075(1, 0x10) # use i2c bus 1, module address is 0x10 while VEML6075.begin() != True: print("VEML6075 begin faild") time.sleep(2) print("VEML6075 begin succeed") while True: Uva = VEML6075.getUva() # get UVA Uvb = VEML6075.getUvb() # get UVB Uvi = VEML6075.getUvi(Uva, Uvb) # get UVI print("") print("======== start print ========") print("UVA: %.2f" %(Uva)) print("UVB: %.2f" %(Uvb)) print("UVA: %.2f" %(Uvi)) print("mw/cm^2: %.2f" %(VEML6075.Uvi2mwpcm2(Uvi))) print("======== end print =========") time.sleep(1) Read UV data on Raspberry Pi. Servo Controlling Example Gravity:IO Expansion HAT for Raspberry Pi has 4-way PWM ports to convenient users to use on Rasbperry Pi. Input the following commands to install the library: cd ~ git clone https://github.com/DFRobot/DFRobot_RaspberryPi_Expansion_Board.git Run the demo-servo program, then we can see the servo will rotate from 0 to 180 and then rotate back. Click "ctrl+c" to exit the program execution. # -*- coding:utf-8 -*''' # # # # # # # # # # # # # # # ''' demo_servo.py Connect board with raspberryPi. Run this demo. Connect servo to one of pwm channels All or part servos will move to 0 degree, then move to 180 degree, then loop Test Servo: https://www.dfrobot.com/product-255.html Warning: Servos must connect to pwm channel, otherwise may destory Pi IO Copyright Copyright [DFRobot](http://www.dfrobot.com), 2016 GNU Lesser General Public License version V1.0 date 2019-3-28 import time from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_IIC as Board from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_Servo as Servo board = Board(1, 0x10) servo = Servo(board) # Select i2c bus 1, set address to 0x10 ''' print last operate status, users can use this variable to determine the result of a function call. ''' def print_board_status(): if board.last_operate_status == board.STA_OK: print("board status: everything ok") elif board.last_operate_status == board.STA_ERR: print("board status: unexpected error") elif board.last_operate_status == board.STA_ERR_DEVICE_NOT_DETECTED: print("board status: device not detected") elif board.last_operate_status == board.STA_ERR_PARAMETER: print("board status: parameter error") elif board.last_operate_status == board.STA_ERR_SOFT_VERSION: print("board status: unsupport board framware version") if __name__ == "__main__": while board.begin() != board.STA_OK: print_board_status() print("board begin faild") time.sleep(2) print("board begin success") servo.begin() # servo control begin while True: print("servo move to 0") servo.move(board.ALL, 0) time.sleep(1) print("servo move to 180") servo.move(board.ALL, 180) time.sleep(1) print("part servos move to 0") servo.move(0, 0) #pwm0 #servo.move(1, 0) #pwm1 #servo.move(2, 0) #pwm2 #servo.move(3, 0) #pwm3 time.sleep(1) print("part servos move to 180") servo.move(0, 180) #pwm0 #servo.move(1, 180) #pwm1 #servo.move(2, 180) #pwm2 #servo.move(3, 180) #pwm3 time.sleep(1) # Board begin and check board status Digital Port Example • Plug a LED on the Pin27 on the expansion board, then it will begin to blink on and off. import RPi.GPIO as GPIO import time import atexit blinkPin=27 atexit.register(GPIO.cleanup) GPIO.setmode(GPIO.BCM) GPIO.setup(blinkPin,GPIO.OUT) while True: GPIO.output(blinkPin,GPIO.HIGH) time.sleep(1) GPIO.output(blinkPin,GPIO.LOW) time.sleep(1) UART Port Example Gravity: IO Expansion HAT for Raspberry Pi has 1-way UART port. Take SEN0285 Gesture&Touch Sensor as an example, click to download DFRobot_Gesture_Touch library. Input the following commands into the terminal: cd ~ git clone https://github.com/DFRobot/DFRobot_Gesture_Touch.git Run the demo_gesture_touch program. Analog Port Example Gravity:IO Expansion HAT for Raspberry Pi has 4-way analog ports. Input the following commands into the terminal to install the library: cd ~ git clone https://github.com/DFRobot/DFRobot_RaspberryPi_Expansion_Board.git Download and run the demo_adc program. # -*- coding:utf-8 -*''' # demo_adc.py # # # # # # # # # # # ''' Connect board with raspberryPi. Run this demo. All or part adc channels value will print on terminal Copyright Copyright [DFRobot](http://www.dfrobot.com), 2016 GNU Lesser General Public License version V1.0 date 2019-3-28 import time from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_IIC as Board board = Board(1, 0x10) # Select i2c bus 1, set address to 0x10 def board_detect(): l = board.detecte() print("Board list conform:") print(l) ''' print last operate status, users can use this variable to determine the result of a function call. ''' def print_board_status(): if board.last_operate_status == board.STA_OK: print("board status: everything ok") elif board.last_operate_status == board.STA_ERR: print("board status: unexpected error") elif board.last_operate_status == board.STA_ERR_DEVICE_NOT_DETECTED: print("board status: device not detected") elif board.last_operate_status == board.STA_ERR_PARAMETER: print("board status: parameter error") elif board.last_operate_status == board.STA_ERR_SOFT_VERSION: print("board status: unsupport board framware version") if __name__ == "__main__": board_detect() # If you forget address you had set, use this to detected them, must have class instance # Set board controler address, use it carefully, reboot module to make it effective ''' board.set_addr(0x10) if board.last_operate_status != board.STA_OK: print("set board address faild") else: print("set board address success") ''' while board.begin() != board.STA_OK: print_board_status() print("board begin faild") time.sleep(2) # Board begin and check board status print("board begin success") board.set_adc_enable() # board.set_adc_disable() while True: val = board.get_adc_value(board.A0) #val = board.get_adc_value(board.A1) #val = board.get_adc_value(board.A2) #val = board.get_adc_value(board.A3) print("channel: A0, value: %d" %val) print("") # A0 channels read # A1 channels read # A2 channels read # A3 channels read time.sleep(2) PWM Example Gravity:IO Expansion HAT for Raspberry Pi offers 4-way PWM ports. Input the following commands into the terminal to install the library: cd ~ git clone https://github.com/DFRobot/DFRobot_RaspberryPi_Expansion_Board.git Download and run the demo_pwm program # -*- coding:utf-8 -*''' # demo_pwm.py # # Connect board with raspberryPi. # Run this demo. # # All pwm channel will set frequency to 1000HZ, duty to 50%, attention: PWM voltage depends on independent power supply # If there is DC motors connect to pwm channle, they will move slow to fast, then loop # # Copyright [DFRobot](http://www.dfrobot.com), 2016 # Copyright GNU Lesser General Public License # # version V1.0 # date 2019-3-28 ''' import time from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_IIC as Board board = Board(1, 0x10) # Select i2c bus 1, set address to 0x10 def board_detect(): l = board.detecte() print("Board list conform:") print(l) ''' print last operate status, users can use this variable to determine the result of a function call. ''' def print_board_status(): if board.last_operate_status == board.STA_OK: print("board status: everything ok") elif board.last_operate_status == board.STA_ERR: print("board status: unexpected error") elif board.last_operate_status == board.STA_ERR_DEVICE_NOT_DETECTED: print("board status: device not detected") elif board.last_operate_status == board.STA_ERR_PARAMETER: print("board status: parameter error") elif board.last_operate_status == board.STA_ERR_SOFT_VERSION: print("board status: unsupport board framware version") if __name__ == "__main__": board_detect() # If you forget address you had set, use this to detected them, must have class instance # Set board controler address, use it carefully, reboot module to make it effective ''' board.set_addr(0x10) if board.last_operate_status != board.STA_OK: print("set board address faild") else: print("set board address success") ''' while board.begin() != board.STA_OK: print_board_status() print("board begin faild") time.sleep(2) print("board begin success") # Board begin and check board status board.set_pwm_enable() # Pwm channel need external power # board.set_pwm_disable() board.set_pwm_frequency(1000) # Set frequency to 1000HZ, Attention: PWM voltage depends on independent power supply while True: print("set all pwm channels duty to 30%") board.set_pwm_duty(board.ALL, 30) # Set all pwm channels duty time.sleep(1) print("set part pwm channels duty board.set_pwm_duty(0, 60) # Set #board.set_pwm_duty(1, 70) # Set #board.set_pwm_duty(2, 80) # Set to 60%") pwm0 channels duty pwm1 channels duty pwm2 channels duty #board.set_pwm_duty(3, 90) time.sleep(1) # Set pwm3 channels duty SPI Port Example Refer to DFR0413 Inch OLED Display Module For Raspberry Pi Wiki. FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum https://www.dfrobot.com/product-1930.html?search=DFR0566&description=true/12-5-19
DFR0566 价格&库存
很抱歉,暂时无法提供与“DFR0566”相匹配的价格&库存,您可以联系我们找货
