DFR0569
DFR0569
    DFROBOT
    - DC/DC,步升/步降 1,非隔离 输出评估板
DFR0569 数据手册
          DC-DC Automatic Step Up-down Power Module (3~15V to 5V 600mA) SKU:DFR0569    INTRODUCTION This power module contains the function of automatic buck-boost and integrates with the related circuit of buck-boost converter. Its size is just as same as a dime, which is very easy for embedding. Input voltage range 3~15V, fixed output voltage 5V, the maximum load current is 0.6A and its quiescent current is as low as 200uA. In theory, the work frequency of the module can reach to 1.2MHz. Besides, it has steady output voltage, which can work long time without voltage shift. The maximum conversion can reach to 85%. So it is suitable for the occasions with high requirements. You can use this power module to DIY mobile power pack and provide constant power for your projects. FEATURES  Small size, stable performance, wide voltage range for a variety of DIY applications APPLICATIONS Power supply for controller main-board, DIY current source, floodlight, DIY toy car, communication device, digital radio. Serial number  Name  Direction  Application  1  Vo+  output  Output positive current source  2  Vo‐  output  Ground wire, output port current source reference  3  Vi‐  input  Ground wire, link to current source reference  4   Vi+  input  Power supply input:2.5‐15Vdc    Figure1. Interface Description          Figure2.Typical Performance Characteristics(Conversion)  SPECIFICATION               Input Voltage: 3~15Vdc Output Voltage: 5V  Output Accuracy: ±0.1V  The Maximum Output Peak Current: 600mA  Full‐Load Output Ripple: Vpp
DFR0569 价格&库存
很抱歉,暂时无法提供与“DFR0569”相匹配的价格&库存,您可以联系我们找货
DFR0569
  • 1+45.711211+5.92120
  • 3+40.302633+5.22060
库存:2
