DFR0578
DFR0578
    DFROBOT
    I/O 扩展 接口 Gravity 平台评估扩展板
DFR0578 数据手册
        Gravity: I/O Expansion Shield for OpenMV Cam M7 SKU:DFR0578   Gravity: I/O Expansion Shield for OpenMV Cam M7 is an expansion shield specially designed for the OpenMV Cam M7. It is compatible with various sensors and electronic modules of Gravity Series, plug and play, no soldering required. It not only helps you avoid the complex wiring , welding and other operations, but also helps you quickly complete wiring and get started with the sensors or electronic modules, to build prototypes faster. This expansion shield is equipped with a 5V external power supply port and a 3.3V/VIN power switch, which makes the expansion shield able to drive high current components such as motors and servos. There are 9 sets of digital ports, 1 set of analog port, 1 set of serial port and 2 sets of I2C ports on the expansion shield. Additional, there is an onboard 3.3V LDO, which meets the power demand of multiple modules at the same time. 1.The USB port of the expansion shield is only used for power supply, so it cannot be used  for programming or debugging. The continuous current of the USB port is recommended  to be controlled within 1A.  2.When put the expansion shield on the OpenMV motherboard, please pay attention to  the direction. The USB port of the expansion shield should be on the same side as the USB  port of the OpenMV motherboard.  3.Because OpenMV motherboard works at 3.3V, limited by the voltage, it does not support  5V analog input. All signal pins are 0~3.3V.  4.If you need to drive high current components such as servos and motors, please connect  them to P7~P9 ports, then connect the external power supply, and turn the power switch  to VIN side. Otherwise, the OpenMV motherboard may be damaged due to high current.  5.The power supply of P7,P8,P9 port can be selected 3.3V or VIN by the power switch. The  power supply voltage of the remaining ports are all 3.3V.      Specification          External Power Supply Voltage (onboard USB port): 5.0±0.1V External Power Input Current (onboard USB port):
DFR0578 价格&库存
很抱歉,暂时无法提供与“DFR0578”相匹配的价格&库存,您可以联系我们找货
