Gravity: Digital 1-to-8 I2C Multiplexer
SKU:DFR0576
On the same I2C port, DFRobot Gravity: I2C Multiplexer solves the address conflict and enables the
normal communication with multiple same-address I2C devices.
You just found the sensor you needed, and you want to wire up two or more to the I2C port of your
mainboard, but later you realized that they have the fixed I2C address! That is, you can not use them
on the same I2C port! Are you out of luck? Now don’t worry! DFRobot Gravity: I2C Multiplexer can
easily solve the address conflict on the same I2C port.
This I2C multiplexer is easy to use, plug and plug and no need to weld. 1 multiplexer has 8 I2C
ports, this means you can hook up 8 same-address devices at the same I2C port by 1 multiplexer.
The default I2C address of the multiplexer is 0x70, and you can adjust from 0x70 to 0x77. In theory,
you could hook up 8 multiplexers on address 0x70~0x77, to control 64 same-address devices. So
powerful!
Specification
Operating Voltage: 3.3~5.0V
Connector Type: PH2.0-4P
Interface Level: high 3.3V, low 0V
Interface Protocol: I2C(IIC)
I2C Clock Rate: 100K, 400K
I2C Port Quantity: 8
Default I2C Address: 0x70 (dial switches all to 0)
I2C Address Range: 0x70~0x77
Dimension: 32*32mm / 1.26*1.26in
Board Overview
Num
C
D
R
Label
VCC
GND
SCL
SDA
RESET
Description
Power VCC(3.3~5V)
Power GND(0V)
I2C Clock Line - SCL
I2C Data Line - SDA
RESET PIN, Active Low
Dial Switch Description:
As shown in the picture above, the dial switchs are all turned to the right(marked with '0') by default,
at this time, A2,A1,A0 are all low level, so the default address of the multiplexer is 0x70. If the dial
switchs are all turned to the left(marked with ‘1’), then A2,A1,A0 are all high level, and the address is
0x77. You can adjust the dial switchs as needed to set the address. You can set it from 0x70 to
0x77.
Tutorial
This tutorial uses two OLED displays as an example to demonstrate how to use this I2C multiplexer.
The OLED display used in this example has the fixed I2C address, so these two OLED displays
cannot be directly hooked up to the same I2C port. However, through this I2C multiplexer's transfer,
these two OLED displays can be normally used on the same I2C port at the same time.
Requirements
Hardware
DFRduino UNO R3 (or similar) x 1
Gravity: I2C Multiplexer x 1
Gravity I2C OLED-2864 Display (or similar) x2
Gravity 4pin UART/I2c Cable (or several DuPont Cables) x3
Software
Arduino IDE (Version requirements: V1.0.x or V1.8.x), Click to Download Arduino IDE from Arduino®
Library:DFRobot_I2C_Multiplexer Library
Connection Diagram
Sample Code
Please down the DFRobot_I2C_Multiplexer Library,DFRobot_SSD1306
Library,DFRobot_Display Library and install it.
How to install Libraries in Arduino IDE
* file Multi_SSD1306.ino
* Download Display library https://github.com/DFRobot/DFRobot_Display.git
* Download SSD1306 library https://github.com/DFRobot/DFRobot_SSD1306.git
* Connect the 2 SSD1306 devices to the port 0 and port 1 on the i2cmultipl
exer respectively and then connect the I2cmultiplexer and Arduino, download t
his sample.
* @n The address of I2C and the name of SSD1306 display module can be seen
* Copyright
[DFRobot](http://www.dfrobot.com), 2016
* Copyright
GNU Lesser General Public License
* version
* date
V0.1
2018-5-10
#include "DFRobot_SSD1306_I2C.h"
#include "DFRobot_I2CMultiplexer.h"
#include "DFRobot_Character.h"
#include "DFRobot_GT30L.h"
#include
#include
/*Create an OLED object, the address is 0x3c*/
DFRobot_SSD1306_I2C OLED(0x3c);
/*Create an I2C Multiplexer object, the address of I2C Multiplexer is 0X70*/
DFRobot_I2CMultiplexer I2CMulti(0x70);
void setup(void){
/*Let the OLED on port 0 display characters*/
I2CMulti.selectPort(0);
//Select port
OLED.begin();
//initialize OLED
OLED.setTextColor(1);
OLED.setTextSize(2);
OLED.setCursor(0,0);
// Set the corrdianate of characters
OLED.print("device A");
//Display characters
OLED.setCursor(0,30);
OLED.print("addr:0x3C");
/*Let OLED on
port 1 display
I2CMulti.selectPort(1);
OLED.begin();
OLED.print("device B");
void loop(void){
characters */
Expected Results
As shown in the picture below, although these two OLED displays have the same I2C addresses,
they work normally after this I2C multiplexer's transfer.
Software Framework
Through the above example, we have already understood how to use this I2C multiplexer's
hardware and software library. Now we summarize further, and get the following software
framework. This will help you better understand the software library and apply it to your project.
#include
/*Create an I2C Multiplexer object, the default address of I2C Multiplexer is
0X70*/
void setup(void)
//Select Port 0
//Initialize the I2C Device on Port 0
//Select Port 1
//Initialize the I2C Device on Port 1
I2CMulti.selectPort(8);
//Select Port 8
//Initialize the I2C Device on Port 8
void loop(void)
//Select Port 0
//Communicate with the I2C Device on Port 0
//Select Port 1
//Communicate with the I2C Device on Port 1
//Select Port 8
//Communicate with the I2C Device on Port 8
https://www.dfrobot.com/wiki/index.php/Gravity:_Digital_1‐to‐8_I2C_Multiplexer_SKU:DFR0576 9‐11‐18
很抱歉,暂时无法提供与“DFR0576”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+75.693971+9.84230
