Solar Power Manager For 12V Lead‐Acid
Battery SKU: DFR0580
Solar Power Manager Series
Introduction
The DFRobot Solar Power Manager series are designed for IoT and renewable energy projects,
providing safe and high-efficiency embedded solar power management modules for makers and
application engineers. All modules of this series feature as MPPT (Maximum Power Point Tracking)
to maximize solar energy conversion efficiency under various sunlight. A complete battery and
power protection provides reliable power management for different types of solar projects.
Selection Guide
Name
Solar Power
Manager
Solar Power
Manager 5V
Solar Power Manager Micro
Solar Power
Manager For 12V
Lead-Acid
Battery ★
SKU
DFR0535
DFR0559
DFR0579
DFR0580
Solar Power
Management
IC
LTC3652
CN3065
SPV1050
CN3767
Solar Input
Voltage
7V ~ 30V
4.4V ~ 6V
0.5V ~ 4V
15V~25V
Battery
Maximum
Charge
Current
2A(Solar/USB)
900mA(Solar/USB)
70mA(Solar)/100mA(USB)
4A(Solar)
Topology
DC-DC Buck
Linear Regulator
DC-DC Boost
DC-DC Buck
Battery
3.7V Lithium Battery
3.7V Lithium
Battery
12V Lead-Acid
Battery
MPPT
Yes (9V/12V/18V
Optional)
Yes(Fixed 5V)
75% Open Voltage
Yes(Fixed 18V)
Over Charge/Over
Discharge/Over
Battery
Current/Reverse
Protections
Connection
Protections
Over
Charge/Reverse
Connection
Protections
Short Circuit/Over
Output
Short Circuit/Over
Current/Over Heat
Protections
Current Protections
Protections
Over Charge/Over
Over Charge/Over
Discharge/Reverse
Discharge/Reverse Connection
Connection
Protections
Protections
Short Circuit/Over Current
Protections
Short Circuit/Over
Current/Over Heat
Protections
USB Charge
IN
Yes
Yes
Yes
No
USB OUT
5V 1.5A
5V 1A
No
5V 2.5A x2
Regulated
OUT
Three Regulated
Outputs
3.3V 1A;5V 1.5V
;9V/12V 0.5A
One Regulated
Output
5V 1A
One Regulated Output
3.3V 90mA
Two Outputs
5V 5A; 12V 8A
Dimension
78.0mm×68.0mm
33.0mm×63.0mm
30.0mm×30.0mm
68.0mm×68.0mm
A complete
A small and easyMedium power
multifunction solar to-use 5V solar
solar management
A micro power solar power
power
power
module for 12V
management
module for low- lead-acid batteries.
management
management
power sensors and
module.
module.
controllers.
Applications: Street
Features
lighting, intelligent
Applications: Small Applications: Solar
agriculture,
Solar Street Lamp, Power Bank, Solar Applications: Wireless Sensor
Network, BLE iBecon
environmental
Solar Powered
Environment
For 1V/2V/3V Solar Panels
monitoring station
Robots
Monitors
For 18V Solar
within 0.5W
For 9V/12V/18V
For 5V Solar
Panels within
Solar Panels
Panels within
100W
within 20W
10W
Introduction
Solar Power Manager For 12V Lead-Acid Battery is a medium-power high-efficiency solar power
management module, which is able to charge a 12V lead-acid battery with a maximum of 4A using a
standard 18V solar panel. It is suitable for applications within 100W, such as 12V lighting
equipments, security monitoring, small robots, pumps or environmental monitoring stations. It
features as MPPT(Maximum Power Point Tracking) function, maximizing the output power of solar
panels under various sunlight. Compared with common PWM solar controllers, it can improve
charging performance by 10%-30%. Benefited from its small size and light weight, it is easy to
embed it in your projects. The module provides dual high-power outputs 5V 5A (OUT1) and 12V 8A
(OUT2) and dual USB outputs 5V 2.5A (USB1/USB2). Except USB1, all outputs can be turned
ON/OFF by I/O pins of most controllers (3.3V/5V compatible). This feature helps to dynamically
power loads and reduce power consumption. Various protection functions are also employed to
ensure the safety and stability of the solar systems.
Features
Constant voltage (18V fixed) MPPT algorithm, maximizing solar energy conversion
Designed for standard 18V solar panels and 12V lead-acid battery
Multiple high efficiency outputs for 12V or 5V large power devices
Full protection functions, a safe and high efficiency power module
A variety of status indicators, system status at a glance
Specifications
Solar Power Management IC: CN376
Solar Input Voltage (SOLAR IN): 15V~25V
Battery Input (BAT IN): 12V Lead-Acid Battery
Charge Current: 4A Max Trickle Charging, Constant Current, Constant Voltage, Float Charging Four
Stages Charging dedicated for 12V Lead-Acid Battery
Float Charge Voltage: 13.55V
Constant Voltage Stage: 14.8V
Over-discharge Protection Voltage: 10.8V
Over-discharge Protection Release Voltage: 11.8V
Solar Charge Average Efficiency (18V SOLAR IN): 94%
OutputsNote1: OUT1 5V 5A, OUT2 12V 8A, USB1 5V 2.5A, USB2 5V 2.5A
USB1/USB2 Support Three USB Charge ProtocolsNote2
Apple 2.4A:DP=2.7V,DM=2.7V
SAMSUNG 2.0A:DP = 1.2V,DM =1.2V
BC1.2:DP=DM=0V (Short)
OUT1/USB1/USB2 Efficiency: 90%@10%Load, 93%@50%Load, 92%@90%Load
OUT2 Efficiency: 99%@10%Load, 98%@50%Load, 97%@90%Load
Operating Current: 75%
ON
ON
ON
ON
50%
很抱歉,暂时无法提供与“DFR0580”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+251.220231+32.65782
