DFR0597
DFR0597
    DFROBOT
    LED 照明 - COB,驱动器,模块,灯条 7 x 71 红色,绿色,蓝色(RGB) 5V 串行 10.59" 长 x 1.18" 宽(269.00mm x 30.00mm)
DFR0597 数据手册
Flexible RGB LED Matrix 7x71 SKU:DFR0597 INTRODUCTION This flexible RGB LED matrix display has 7x71 RGB LEDs. Designed with flexible PCB board, it is light and bendable. The onboard MCU simplifies the way to display numbers and alphabets. It can keep display status even separated from the main control. So that it can be conveniently integrated into projects, especially wearable devices, such as hats, backpacks, clothes, skirts, shoes, belts, masks, etc. For items, it can be used for wallets, musical instruments, cups, vases, clock ornaments, etc. And it also is used in advertising walls, displays, and holiday decorations. Please kindly note that the flexible RGB LED matrix display should not be over-curved (no more than 30°) and bent repeatedly, so is prone to damage. The screen dimension is 269mm x 30mm, among it the matrix dimension is 232mm x 22mm, and Pixel Pitch is 3.2mm. This flexible RGB LED matrix display supports showing both numbers and alphabets, we recommend to use DFR0598 to show Chinese. Flexible RGB LED Matrix 7x71 NOTE: 1. The flexible PCB board cannot be over-curved (no more than 30°) and bent repeatedly. Although the product can work curvedly, the resulting consequences will not be responsible. 2. Arduino UNO can drive this matrix display. Once the brightness increased, please guarantee it with an independent 5V power supply, otherwise, it may lead to abnormal color show and exceptional display. SPECIFICATION Operating Voltage: 5.0V Rated Current: < 500mA (brightest) Resolution: 7 x 71 Module Dimension: 269x30mm / 10.59x1.18inch Pixel Pitch: 3.2mm Supporting Colors: Red, Yellow, Green, Red, Blue, Purple, White Communication: Serial Port SHIPPING LIST Flexible RGB LED Matrix 7x71 x1 Lightboard Transfer-line x1 https://www.dfrobot.com/product‐1992.html
DFR0597 价格&库存
很抱歉,暂时无法提供与“DFR0597”相匹配的价格&库存,您可以联系我们找货
