Dual-Channel DC Motor Driver-12A
SKU:DFR0601
INTRODUCTION
This is a dual channel DC motor driver with an extremely small size of of
1.97”×1.97”×0.49”. The module comes with two motor channels that can drive two
motors simultaneously, and each channel employs an indicator to show the rotation
direction of the motor: blue is forward rotation, red is reverse rotation. Support motor
voltage ranges from 6.5V to 37V. Each motor channel can output 12A current
continuously and the max power of the DC motor the module supports is up to 290W.
The momentary peak current can reach up to 70A and last about 100ms. At the same
time, the highly timing optimization of the units inside the driver makes the minimum
pulse width of PWM input as narrow as 2us, which fully ensured its dynamic adjustment
range and greatly improved the quality of controlling motors.
The module integrated over-voltage, under-voltage, and overheat protection circuit that
will be triggered when facing with the these situations. There is an on-board STATE
indicator to indicate protection state: ON->Work properly; Flashing quickly->Overvoltage; Flashing slowly->Under-voltage; Double flashing->Overheat. The latter three
situations will turn off the output, which can efficiently reduce the possibility of device
damage in abnormal operating conditions.
Using this dual channel DC motor driver together with Arduino controller is able to easily
realize motor controlling. The module can be applied to automatic robot, mechatronic,
equipment manufacture, scientific production, electronics competition and so on.
Schematic Diagram
Dimension Diagram
Connection Diagram
SPECIFICATION
Motor Channel: 2
Signal Control Voltage: 3V-5V compatible
Input Voltage: 6.5-37V DC
Peak Current: 70A(100ms), the current will be limited as the temperature increases.
Continuous Current: each channel can output 12A current continuously
Operating Temperature: -25-85Ԩ
Overheat Temperature: 85Ԩ-95Ԩ
Over-voltage: 37.5V
Under-voltage: 6.3V
Dimension: 50mm×50mmx12.5mm/1.97”×1.97”×0.49”
Built-in over-voltage, under-voltage and overheat protection circuit, onboard STATE
indicator to show the present work state.
SHIPPING LIST
Dual-Channel DC Motor Driver-12A x1
https://www.dfrobot.com/product‐1862.html?search=DFR0601/7‐12‐19
很抱歉,暂时无法提供与“DFR0601”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+258.850141+33.65765
