ESP32-CAM Development Board
SKU:DFR0602
INTRODUCTION
ESP32-CAM is a low-cost ESP32-based development board with onboard camera, small in
size. It is an ideal solution for IoT application, prototypes constructions and DIY projects.
The board integrates WiFi, traditional Bluetooth and low power BLE , with 2 highperformance 32-bit LX6 CPUs. It adopts 7-stage pipeline architecture, on-chip sensor,
Hall sensor, temperature sensor and so on, and its main frequency adjustment ranges
from 80MHz to 240MHz.
Fully compliant with WiFi 802.11b/g/n/e/i and Bluetooth 4.2 standards, it can be used as
a master mode to build an independent network controller, or as a slave to other host
MCUs to add networking capabilities to existing devices
ESP32-CAM can be widely used in various IoT applications. It is suitable for home
smart devices, industrial wireless control, wireless monitoring, QR wireless
identification, wireless positioning system signals and other IoT applications. It is an
ideal solution for IoT applications.
Schematic Diagram
Dimension Diagram
Notes:
1.Please be sure that the power supply for the module should be at least 5V 2A,
otherwise maybe there would be water ripple appearing on the image.
2.ESP32 GPIO32 pin is used to control the power of the camera, so when the camera is
in working, pull GPIO32 pin low.
3.Since IO pin is connected to camera XCLK, it should be left floating in using, and do
not connect it to high/low level.
4.The product has been equipped with default firmware before leaving the factory, and
we do not provide additional ones for you to download. So, please be cautious when
you choose to burn other firmwares.
FEATURES
Up to 160MHz clock speed,Summary computing power up to 600 DMIPS
Built-in 520 KB SRAM, external 4MPSRAM
Supports UART/SPI/I2C/PWM/ADC/DAC
Support OV2640 and OV7670 cameras, Built-in Flash lamp.
Support image WiFI upload
Support TF card
Supports multiple sleep modes.
Embedded Lwip and FreeRTOS
Supports STA/AP/STA+AP operation mode
Support Smart Config/AirKiss technology
Support for serial port local and remote firmware upgrades (FOTA)
SPECIFICATION
SPI Flash: default 32Mbit
RAM: built-in 520 KB+external 4MPSRAM
Dimension: 27*40.5*4.5(±0.2)mm/1.06*1.59*0.18”
Bluetooth: Bluetooth 4.2 BR/EDR and BLE standards
Wi-Fi: 802.11b/g/n/e/i
Support Interface: UART, SPI, I2C, PWM
Support TF card: maximum support 4G
IO port: 9
Serial Port Baud-rate: Default 115200 bps
Image Output Format: JPEG( OV2640 support only ), BMP, GRAYSCALE
Spectrum Range: 2412 ~2484MHz
Antenna: onboard PCB antenna, gain 2dBi
Transmit Power: 802.11b: 17±2 dBm (@11Mbps);
802.11g: 14±2 dBm (@54Mbps);
802.11n: 13±2 dBm (@MCS7)
Receiving Sensitivity: CCK, 1 Mbps : -90dBm;
CCK, 11 Mbps: -85dBm;
6 Mbps (1/2 BPSK): -88dBm;
54 Mbps (3/4 64-QAM): -70dBm;
MCS7 (65 Mbps, 72.2 Mbps): -67dBm
Power consumption: Turn off the flash: 180mA@5V
Turn on the flash and adjust the brightness to the maximum:
310mA@5V
Deep-sleep: the lowest power consumption can reach 6mA@5V
Moderm-sleep: up to 20mA@5V
Light-sleep: up to 6.7mA@5V
Security: WPA/WPA2/WPA2-Enterprise/WPS
Power supply range: 5V
Operating temperature: -20 °C ~ 85 °C
Sorage environment: -40 °C ~ 90 °C, < 90%RH
Weight: 10g
SHIPPING LIST
ESP32-CAM Development Board x1
https://www.dfrobot.com/product‐1876.html/8‐15‐19
很抱歉,暂时无法提供与“DFR0602”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+104.160701+13.54060
