DFR0604
DFR0604
    DFROBOT
    STM32F030 I/O 扩展 接口 Raspberry Pi Zero 平台评估扩展板
DFR0604 数据手册
IO Expansion HAT for Pi Zero/Zero W SKU:DFR0604 Introduction This DFRobot IO Expansion HAT provides Digital, Analog, I2C, PWM, UART and SPI port to meet all your needs. It is pretty small and perfectly suitable for Raspberry Pi Zero/Zero W. The board leads out the I/O ports on Raspberry Pi including IIC, UART, SPI and digital, among which the digital ports are led out via the GPIO16~GPIO25(BCM) of Raspberry Pi, so these ports can be directly used. Besides, the PWM and Analog ports are led out through the on-board MCU STM32 that can communicate with Raspberry Pi via IIC. So combing with our related libraries, users are able to conveniently use Raspberry Pi to control PWM output or read ADC input. Specification • Power Supply: 5V • External Power Supply (Servo): 6-12V • Device Address: 0x10 • Dimension: 65x30mm/2.56x1.18” Board Overview Silkscreen Label Function + + 3.3 Power Positive - - Negative ⊕ ⊕ External Power Positive ㊀ ㊀ External Power Negative Digital 16-25 Raspberry Pi (GPIO16-GPIO25) Silkscreen Label PWM 0-3 PWM Signal Output P0~3 Analog 0-3 Analog Signal Input P0~3 IIC C IIC Clock line D IIC Data Line T UART Transmit R UART Receive MISO SPI Data Output Line SS SPI Enable Pin SCLK SPI Clock Line MOSI SPI Data Input Line UART SPI Function PWM The PWM signal of this expansion board is generated by the on-board STM32. PWM0~PWM3 are output via multiple channels of one timer with same frequency. The duty ratio can be set by users. PWM4 adopts another timers to output PWM. The PWM can be powered by Raspberry Pi(5V) or external power(6-12V). Note: • When the VP port is not power by external power, the voltage of PWM ⊕ is 5V. • When the VP port is powered by external power, the voltage of PWM ⊕ is equal to that of the VP external power (6-12V). Analog The IO expansion board comes with an on-board MCU STM32 that provides 12 bit ADC. The voltage of analog sensor will be input into the 12-bit ADC sent to Raspberry Pi via IIC when the analog data is converted into digital data, by which to allow Raspberry Pi to read values of analog sensor. Digital The board leads out 10 GPIO (BCM encode) ports of Raspberry Pi: GPIO16, GPIO17, GPIO18, GPIO19, GPIO20, GPIO21, GPIO22, GPIO23, GPIO24, GPIO25. IIC There are two IIC ports on the board, and they are led out via Raspberry Pi's IIC. Connect the two ports to GPIO2(SDA.1)and GPIO3(SCL.1) of Raspberry Pi. UART The UART ports on the expansion board are led out through Pi's GPIO14(TXD)and GPIO15(RXD). Use UART port to communicate with Arduino, Esp8266 and so on. SPI Connect the SPI ports on the board to GPIO12(MOSI)and GPIO13(MISO). Tutorial Connection Plug the IO expansion board into Raspberry Pi. Download the Driver library To use the analog and PWM ports in the board, download the driver library first. Press Ctrl+Alt+T to open the terminal, input the following command and hit Enter. git clone https://github.com/DFRobot/DFRobot_RaspberryPi_Expansion_Board.git Download the library and unzip the file. Input the following command into the terminal: tar -xvzf DFRobot_RaspberryPi_Expansion_Board Enter the directory of the uncompressed files: cd DFRobot_RaspberryPi_Expansion_Board/raspberry/ Extended Ports Usage • PWM: connect a servo to PWM P0. Create a file via the command of nano: sudo nano servoTest.py Add the following content: # -*- coding:utf-8 -*# servoTest.py import time from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_IIC as Board from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_Servo as Servo board = Board(1, 0x10) # Select i2c bus 1, set address to 0x10 servo = Servo(board) if __name__ == "__main__": # Board begin and check the board's status while board.begin() != board.STA_OK: print("Error") time.sleep(1) print("Board begin success.") servo.begin() # servo control begin while True: print("part of servos move to 0°") servo.move(0, 0) # PWM0 ''' servo.move(1, 0) # PWM1 servo.move(2, 0) # PWM2 servo.move(3, 0) # PWM3 ''' print("part of servos move to 180°") servo.move(0, 0) # PWM0 ''' servo.move(1, 0) # PWM1 servo.move(2, 0) # PWM2 servo.move(3, 0) # PWM3 ''' print("All servos move between 0°~180°") for i in range(0, 181): servo.move(board.ALL, i) time.sleep(0.008) time.sleep(0.002) for i in range(0, 181): i = 181 - i servo.move(board.ALL, i) time.sleep(0.008) time.sleep(0.002) In the function servo.move() of the example, the first parameter is the PWM pin of the expansion board, the second one is rotation degree. The PWM selection list is shown below: PWM Pin of IO expansion board Value of the first parameter 0 0 1 1 PWM Pin of IO expansion board Value of the first parameter 2 2 3 3 All Pins board.ALL Press Ctrl+X, and then press Y to save and exit nano editor. Input command sudo raspi-config to open the IIC interface. Input command python servoTest.py to run file servoTest.py. • Analog Sample Code: # -*- coding:utf-8 -*# analogTest.py import time from DFRobot_RaspberryPi_Expansion_Board import DFRobot_Expansion_Board_IIC as Board board = Board(1, 0x10) # Select i2c bus 1, set address to 0x10 if __name__ == "__main__": while board.begin() != board.STA_OK: print("Board begin faild.") time.sleep(1) print("Board begin success.") # Board begin and check the board's status board.set_adc_enable() while True: print("Read part of channels.") val0 = board.get_adc_value(board.A0) ''' val1 = board.get_adc_value(board.A1) val2 = board.get_adc_value(board.A2) val3 = board.get_adc_value(board.A3) ''' print("channel:A0, value:%d" %val0) ''' print("channel:A1, value:%d" %val1) # channel A0 is readed # channel A1 is readed # channel A2 is readed # channel A3 is readed print("channel:A2, value:%d" %val2) print("channel:A3, value:%d" %val3) ''' print("") time.sleep(1) The function board.get_adc_value() in the example is used to get the value of analog port, the pin selection list is shown below: Analog Pin of IO expansion board • Value of the parameter 0 0 1 1 2 2 3 3 All Pins board.ALL Digital: the usage of the digital ports are same with the ways to use GPIO ports of Raspberry Pi. Download the RPi.GPIO first. Input the command on Raspberry Terminal: sudo apt-get install rpi.gpio Input the following command to check is the RPi.GPIO library is installed successfully: gpio.readall If all pins are displayed on the terminal, the library installation succeeds. Take GPIO16 as an example. Connect a LED on P27 of the expansion board. Input the following sample code into nano editor, input python to run the program: # -*- coding:utf-8 -*# digitalTest.py import RPi.GPIO as GPIO import time blinkPin = 16 GPIO.setmode(GPIO.BCM) GPIO.setup(blinkPin, GPIO.OUT) # Set GPIO16 is OUTPUT for i in range(0, 10): GPIO.output(blinkPin, 1) time.sleep(1) GPIO.output(blinkPin, 0) time.sleep(1) GPIO.cleanup() • IIC: for using IIC interface, input the command to enable the Raspberry Pi IIC first: sudo raspi-config Select [Interfacing Options]-[I2C]-[Yes]-[OK]-[Finish]. Restart the Raspberry Pi when completed these steps. The usage of IIC ports on the expansion board is same with that of raspberry Pi, so we will skip here. • UART: The usage of UART ports on the expansion board is same with that of raspberry Pi, so we will skip here. • SPI: for using SPI interface, input the command to enable the Raspberry Pi IIC first: sudo raspi-config Select [Interfacing Options]-[I2C]-[Yes]-[OK]-[Finish].Restart the Raspberry Pi when completed these steps. The usage of SPI ports on the expansion board is same with that of raspberry Pi, so we will skip here. Product Dimension Compatility Test MCU Pass Raspberry Pi 3B √ Raspberry Pi 3B+ √ Raspberry Pi Zero W √ Raspberry Pi 2B+ √ Raspberry Pi Zero √ Raspberry Pi 4B Fail Untest √ Remark FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum More Documents • I/O Expansion HAT for Pi Zero V1.0 Schematics • STM32F030F4P6 Datasheet https://www.dfrobot.com/product-1943.html?search=DFR0604&description=true/12-5-19
DFR0604 价格&库存
很抱歉,暂时无法提供与“DFR0604”相匹配的价格&库存,您可以联系我们找货
DFR0604
  • 1+124.737721+16.21550
  • 3+110.047363+14.30580
库存:3
