DRI0047
DRI0047
    DFROBOT
    有刷 4.8 ~ 8.4V 电源 20A 负载
DRI0047 数据手册
      20A Bidirectional Brushed ESC Speed Controller without Break (XT60 Connector) SKU:DRI0047   INTRODUCTION ESC (Electronic Speed Controller) can be divided into brushed ESC and brushless ESC according to the different motor types. It is widely used in the RC remote control system and we can use signal to control the speed. This is a 20A bidirectional brushed ESC without Break. It can support up to 20A continuous current and 320A instantaneous current. It is controlled by PPM signal and can drive the forward and reverse rotation of the motor. Support RC remote controller of commonly used brands on the market. NOTE: 1. Please carefully read the product specifications before using the equipment, do not  overpressure or overload.  2. Signal Status: After the ESC is energized, the indicator light flashes once again. After the remote  controller back to middle position, the indicator light flashes once again. After the signal is lost,  the indicator light flashes rapidly.  3. How to calibrate?    Plug the ESC signal cable into the corresponding channel of the receiver, turn on the power of the  remote controller, push the joystick of the corresponding channel to the maximum position, then, turn  on the power of ESC, the indicator light will be blinking, after a few seconds, the indicator light will flash  twice, then turn the joystick to the middle position, the indicator light flashes three times again, success!  SPECIFICATION            Type: bidirectional brushed ESC Continuous current: 20A  Voltage range: 4.8V‐8.4V (lithium battery 2S)  Peak current: 320A forward, 320A backward  Output line: power line and motor line 16AWG‐100mm  Control signal type: PPM  Power Connector: XT60 banana plug  Motor Connector: 4mm banana plug  Motor: Brushed motor (260/370/380/540)  Dimensions: L42mm, W28mm, H15mm (including heat sink)  Weight: 30g    SHIPPING LIST  20A Bidirectional Brushed ESC Speed Controller without Break (XT60 Connector) x1                                                             https://www.dfrobot.com/product‐1769.html 8‐7‐18
DRI0047 价格&库存
很抱歉,暂时无法提供与“DRI0047”相匹配的价格&库存,您可以联系我们找货
