FIT0096-C
FIT0096-C
    DFROBOT
    无焊剂试验电路板 端子条(无框架) 3.23" 长 x 2.44" 宽(82.0mm x 62.0mm)
FIT0096-C 数据手册
  400 TIE POINT INTERLOCKING SOLDERLESS BREADBOARD – Crystal SKU:FIT0096-C INTRODUCTION The 400 Tie Point Interlocking Solderless Breadboard is a cute half size breadboard, good for small projects. It is 8.2cm(3.23") x 6.2cm(2.44") in size with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as 3.5cm and stick it onto an Arduino protoshield. You can also cut these in half with a saw to create 2 tiny breadboards, or "snap" these breadboards together either way to make longer or wider breadboards. SPECIFICATION         400 Tie Points Self-adhesive Can be interlocked for larger projects 2 power lanes Horizontal: 1-30 Vertical: A-J Dimensions: 8.2cm x 6.2 cm(3.23"x2.44") Crystal https://www.dfrobot.com/product-577.html 8-15-17
FIT0096-C 价格&库存
很抱歉,暂时无法提供与“FIT0096-C”相匹配的价格&库存,您可以联系我们找货
