FIT0199-S
FIT0199-S
    DFROBOT
    RUBBER WHEEL SET D65MM SILVER
FIT0199-S 数据手册
    D65mm Rubber Wheel Pair ‐ Silver (Without Shaft)  SKU: FIT0199‐S        INTRODUCTION These are typical rubber wheels for small robot mobile platforms. The tire is soft black rubber with light  tread for added traction in rugged terrain.   An axis adapter is needed which bolts to the back of the hub and mounts to a motor. this adapter(Wheel  ‐ Motor Adapter) can mount to our Micro DC Geared Motor with Back Shaft(FIT0016).   These motors are commonly used in our 4WD and 2WD platforms like Turtle (2WD Arduino Mobile  Robot Platform), Pirate (4WD Mobile Platform), Baron(4WD Arduino Mobile Robot Platform with  Encoder) ....  We've prepared 3 different colors for you to choose: Red/Blue/Silver. Enjoy    You will need our Motor Adapter to fit this into Gear motor.      SPECIFICATION     Tire matrerial: Rubber   Outside diameter: 65mm(2.56")  Tire width: 26mm(1.02")  Hub color: Silver  SHIPPING LIST  Rubber wheel  x2                                                          Powered By DFRobot © 2008-2017
FIT0199-S 价格&库存
很抱歉,暂时无法提供与“FIT0199-S”相匹配的价格&库存,您可以联系我们找货
