FIT0513
FIT0513
    DFROBOT
    Gravity 缆线组件
FIT0513 数据手册
  Gravity 4Pin IIC/I2C/UART Sensor Cable (10pcs) SKU:FIT0513 INTRODUCTION The Gravity 4Pin IIC/I2C/UART sensor cable is a standard Gravity series 4-Pin cable with 30cm length. One side is PH2.0-4p connector and the other side is XH2.54 DuPont port. it is compatible with standard breadboard pin pitch, which makes it easy to make a DIY application. The cable uses the colorcoded design to distinguish between the positive and negative power supply, I2C SDA & SCL, UART RX &TX. Easy to recognize and use. SPECIFICATION  Withstand Voltage:
FIT0513 价格&库存
很抱歉,暂时无法提供与“FIT0513”相匹配的价格&库存,您可以联系我们找货
FIT0513
    • 1+53.086181+6.84856
    库存:12
