FIT0520
FIT0520
    DFROBOT
    直流电机 齿轮电机 300 RPM 2W 增量式 6VDC
FIT0520 数据手册
    Metal DC Geared Motor w/Encoder - 6V 300RPM 3.6Kg.cm SKU:FIT0520 INTRODUCTION This is a metal geared DC motor w/Encoder. It is a 6V motor with a 20:1 metal gearbox and an integrated quadrature encoder that provides a resolution of 11 counts per revolution of the motor shaft, which corresponds to 224.4 counts per revolution of the gearbox’s output shaft. These units have an 8 mm length, 4 mm-diameter D-shaped output shaft. This motor is intended for use at 6V, though the motor can begin rotating at voltages as low as 1V. This motor is an ideal option for your mobile robot project. Dimension SPECIFICATION Motor Rated Voltage: 6V Encoder Rated Voltage: 3.3 / 5V Reducer Reduction Ratio: 1: 20 No load Speed: 300RPM@0.1A Maximum Efficiency Point: load 0.7Kg·cm / 245RPM / 1.2W / 0.4A Maximum Power point: Load 1.8Kg·cm / 160RPM / 2W / 0.8A Stall Torque: 3.6kg · cm Stall Current: 2.7A Hall Resolution: Hall Resolution 11x Precision Reduction Ratio 20.4 = 224.4PPR/ RPM Dimension: 50 * Φ24.4 mm / 1.97 * Φ0.96inches Weight: 96g SHIPPING LIST Metal DC Geared Motor w/Encoder - 6V 300RPM 3.6Kg.cm x1 JST 6-Pin cable x1                                            https://www.dfrobot.com/product‐1619.html 9‐19‐17
FIT0520 价格&库存
很抱歉,暂时无法提供与“FIT0520”相匹配的价格&库存,您可以联系我们找货
FIT0520
  • 1+244.607631+31.79820
  • 3+215.835383+28.05790
库存:3
