Metal DC Geared Motor w/Encoder - 6V
100RPM 6.5Kg.cm
SKU:FIT0522
INTRODUCTION
This is a metal geared DC motor w/Encoder. It is a 6V motor with a 75:1 metal gearbox and an
integrated quadrature encoder that provides a resolution of 11 counts per revolution of the
motor shaft, which corresponds to 823.1 counts per revolution of the gearbox’s output shaft.
Pinmap
These units have an 10 mm length, 4 mm-diameter D-shaped output shaft. This motor is
intended for use at 6V, though the motor can begin rotating at voltages as low as 1V. This motor
is an ideal option for your mobile robot project.
Dimension
SPECIFICATION
Motor Rated Voltage: 6V
Encoder Rated Voltage: 3.3 / 5V
Reducer Reduction Ratio: 1: 75
No load Speed: 100RPM@0.13A
Maximum Efficiency Point: Load 1.0kgꞏcm/80RPM/1.7W/0.5A
Maximum Power point: Load 3.0kgꞏcm/55RPM/2.8W/1.0A
Stall Torque: 6.5kgꞏcm
Stall Current: 3.0A
Hall Resolution: Hall Resolution 11x Precision Reduction Ratio 74.83=823.1PPR
Dimension: 54 * Φ24.4 mm / 2.13 * Φ0.96inches
Weight: 96g
SHIPPING LIST
Metal DC Geared Motor w/Encoder - 6V 100RPM 6.5Kg.cm x1
JST 6-Pin cable x1
https://www.dfrobot.com/product‐1618.html/2‐20‐20
很抱歉,暂时无法提供与“FIT0522”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+189.008201+24.39723
