FIT0530
FIT0530
    DFROBOT
    箱 金属 - 铝 黑色 手持,分叉式双侧 3.050" 长 x 2.130" 宽(77.47mm x 54.10mm) X 1.200"(30.48mm)
FIT0530 数据手册
      Aluminum Alloy Case for LattePanda SKU:FIT0530 INTRODUCTION This aluminum alloy case is a solid enclosure for LattePanda single board computer. It adopts to CNC machining and manufacturing, anodic oxidation surface treatment process. The inner space is enough to mount cooling fan (the total thickness of fan should be less than 7.7mm). And the vent and connection hole are all reserved to mount touch panel, display and cooling fan. What is LattePanda? A LattePanda is a complete Windows 10 single board computer. It has everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda. SPECIFICATION  Compatible: LattePanda 2G/32GB & 4G/64GB  Material: Aluminum Alloy  Dimension: 77.5 * 54.25 * 30.5/ 3.05 * 2.13 * 1.2 inches SHIPPING LIST  Aluminum Alloy Case for LattePanda x1  Accessory material package x1    LattePanda cooling fan x1                                                 https://www.dfrobot.com/wiki/index.php/Bluno_M0_Mainboard_SKU:_DFR0416 12‐8‐17
FIT0530 价格&库存
很抱歉,暂时无法提供与“FIT0530”相匹配的价格&库存,您可以联系我们找货
FIT0530
