7 inches Touch Display(eDP) for
LattePanda Alpha&Delta
SKU:FIT0551
Excellent Visual Effect
This display adopts IPS screen technology, support 178-degree visual Angle, 1024 x 600 high
resolution and high color saturation, achieve excellent picture.
Designed For HMI and Portable Projects
We have made many product design optimizations for HMI and portable project
requirements. For example, HMI scenarios are often complex and dusty, but this display
uses a fully fit design to perfectly prevent dust from entering the screen, and also
effectively reduces the reflection of light. In order to make the screen easy to be
installed, the screen edge comes with the special double-sided adhesive tape, which
can be easily and firmly fixed.
Best Compatibility
Unlike other normal HDMI screens, this display uses eDP interface, and has the best
compatibility with LattePanda alpha & delta (not compatible with LattePanda V1.0). It
allows you to set screen power, brightness, contrast and other parameters directly in the
OS or APIs.
lattepanda alpha accessories - Titan Case, Streaming Cable, and 7 inch EDP display
FEATURES
1024 x 600 high resolution
Capacitive screen
SPECIFICATION
Transmittance:85%
Surface Hardness: 6H
Response Time: ≤16ms
Tapping Durability: 200,000,000 times
Supports LattePanda Alpha & Delta
Connector: 10cm FPC Extension Cable
Dimensions: 180*110*5 mm / 7.1*4.3*0.2 inches
SHIPPING LIST
7”eDP Touch Display x1
30pin eDP cable x1
https://www.dfrobot.com/product‐1853.html?search=FIT0551/6‐10‐19
很抱歉,暂时无法提供与“FIT0551”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+789.779331+102.26034
