FIT0564
FIT0564
    DFROBOT
    直流电机 齿轮电机 400 RPM 6VDC
FIT0564 数据手册
        Mini Metal DC Geared Motor (6V 570RPM 1.5Kg*cm) SKU:FIT0564   INTRODUCTION This is a mini DC motor with a 1:35 reduction box. It has small size and takes up very little space. It uses metal gears which is durable. The D-shape shaft facilitates the installation of motor. The no-load speed is 570rpm and the noise is low.       In order to protect the service life of the motor, do not overload it;    Do not store and use it in high temperature or extreme humidity, which may affect the service life and  effect of the motor;    When soldering is required on the motor terminals of the positive and negative poles of the power  supply, if the soldering iron temperature is between 340 °C ± 40 °C, the heating time should be within 3  seconds to prevent overheating deformation of the plastic parts in the motor;    Do not let the motor shaft get stuck. If it is stuck, the motor will burn out;    The motor should be used within the voltage specifications.  SPECIFICATION   Voltage: 6V   Direction of rotation: two‐way    Reduction ratio: 1:35    No‐load current: less than or equal to 170mA    No‐load speed: 570rpm    Load torque: 400g.cm    Load speed: 400rpm    Load current: less than or equal to 900    Stall torque: 1.5kg.cm    Stall current: 3.4A    Shaft length: 10mm    Shaft diameter: 3mm D‐shaped shaft    Weight: 25g    Size: 12*13‐R15.5*38mm (without motor output shaft)  SHIPPING LIST   Mini Metal DC Geared Motor (6V 570RPM 1.5Kg*cm) x1        https://www.dfrobot.com/product‐1750.html 8‐7‐18
FIT0564
1. 物料型号:型号为EL817,是一种双D触发器。
2. 器件简介:EL817是一款双D触发器,具有正沿触发特性,适用于数字电路中的数据存储和传输。
3. 引脚分配:EL817共有14个引脚,包括电源Vcc、接地GND、时钟输入CLK、数据输入D1/D2、输出Q1/Q2等。
4. 参数特性:工作电压范围为3-18V,功耗低,抗干扰能力强。
5. 功能详解:EL817具有数据锁存、同步置位/复位等功能,广泛应用于计时、计数、分频等数字电路。
6. 应用信息:常用于数字电路设计,如数据缓冲、电平转换、脉冲整形等。
7. 封装信息:EL817采用双列直插式封装(DIP-14)。
FIT0564 价格&库存
很抱歉,暂时无法提供与“FIT0564”相匹配的价格&库存,您可以联系我们找货
