FIT0576
FIT0576
    DFROBOT
    模拟板,预穿孔绝缘 无镀层通孔(NPTH) 一孔一焊盘(圆形) 0.100"(2.54mm)
FIT0576 数据手册
          Single Sided ProtoBoard (18x30cm) SKU:FIT0576   INTRODUCTION This is a soft thin protoboard with hole diameter of 1mm, hole spacing of 2.54mm. It can be soldered DIP and SMD components, and the thickness is only 0.4mm. The proto board can be appropriate bending in any direction (depending on the size of the proto board). In the actual application, it can be cropped to any size and shape according to your needs, making circui experiments and design more convenient and fast. SPECIFICATION   Dimensions: 18cm*30cm (7''x11.8'')   Substrate material: high quality FR‐4    Flame retardant properties: VO    Thickness: 0.4mm    Aperture: 1mm (5% error)    Hole spacing: 2.54mm (100mil)  SHIPPING LIST   Single Sided ProtoBoard (18x30cm) x1                                                  https://www.dfrobot.com/product‐1754.html 8‐7‐18
FIT0576 价格&库存
很抱歉,暂时无法提供与“FIT0576”相匹配的价格&库存,您可以联系我们找货
FIT0576
    • 1+154.553081+20.09140
    • 3+137.254963+17.84270
