Micro Metal DC Geared Motor with Long Shaft (6V
98RPM M3*25)
SKU:FIT0578
INTRODUCTION
This DC gearmotor has an integrated M3*25mm long rod as its output shaft, turn it into a linear
actuator. 6V rated voltage, the no-load speed could arrive 98RPM. The brass faceplate has two
mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or you can
use the mounting bracket or extended mounting bracket, which are specifically designed to
securely mount the gear motor while enclosing the exposed gears.
SPECIFICATION
Reduction ratio: 1:150
Standard operating voltage: 6V
No‐load current: 24±10% mA (Max)
No‐load speed: 98±10% r/min
Load current: 185±10% mA (Max)
Load speed: 60±10% r/min
Load: 550g*cm
Stall current: 420 ± 10% mA (Max)
Locking torque: 1000g*cm
Single weight: about 10g
Mechanical noise: ≤50dB (measured at about 10cm from the gearbox)
SHIPPING LIST
Micro Metal DC Geared Motor with Lead Screw (6V 98RPM M3*20) x1
https://www.dfrobot.com/product‐1735.html 7‐16‐18
很抱歉,暂时无法提供与“FIT0578”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+103.132231+13.36790
- 3+91.014413+11.79720
