Micro Metal DC Geared Motor (6V 50RPM 250g*cm)
SKU:FIT0579
INTRODUCTION
This motor has a long (0.365" or 9.27 mm), D-shaped metal output shaft that matches the Pololu
wheel 42x19mm and 32x7mm. The brass faceplate has two mounting holes threaded for M1.6
screws (1.6 mm diameter, 0.35 mm thread pitch), or you can use the mounting bracket or
extended mounting bracket, which are specifically designed to securely mount the gearmotor
while enclosing the exposed gears. We recommend the extended mounting bracket for wheels
with recessed hubs, such as the wheel 42×19 mm.
This motor is suitable to be used in the mini mobile platform. As the 2 wheels miniQ platform, it
can directly work with the MiniQ Robot chassis Encoder, mounting bracket and directly
compatible with wheels.
SPECIFICATION
Reduction ratio: 1:298
Standard operating voltage: 6V
No‐load current: 24±10% mA (Max)
No‐load speed: 50±10% r/min
Load current: 61±10% mA (Max)
Load speed: 46±10% r/min
Load: 250g*cm
Stall current: 430 ± 10% mA (Max)
Locking torque: 2200g*cm
Single weight: about 10g
Mechanical noise: ≤50dB (measured at about 10cm from the gearbox)
SHIPPING LIST
Micro Metal DC Geared Motor with Lead Screw (6V 98RPM M3*20) x1
https://www.dfrobot.com/product‐1736.html 7‐16‐18
很抱歉,暂时无法提供与“FIT0579”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+76.974281+9.96660
