High Temperature Resistant Silicone Wire (10AWG
6mm2 1m Red & Black)
SKU:FIT0581
INTRODUCTION
This product is high temperature resistant silicone wire with 10AWG and 6mm2.It is made of
fine tin-plated copper material and not easily oxidized.It adopts the process of mutual twisting ,
which reduces the signal interference and improves the conductive property. The allowable load
voltage is AC600V/DC3KV and the load current reaches 140A. The insulating layer is a silica
gel material with excellent performance. The insulating layer is thin but not easy to be broke
down. It has elasticity, toughness and acid and alkali resistance. Normally, it can be used at
temperatures from -60 ° C to +200 ° C, can be used for robots , ESC, motors, robot arms,
aeromodelling, car models, and ship models which require high wire performance.
NOTE:
The power supply should not exceed the rated voltage to avoid affecting the wire life.
It should be avoided using over the temperature range of ‐60 ° C ~ +200 ° C
FEATURES
High temperature resistant, low temperature resistant , not easy to breakdown, high voltage and high
current resistant
SPECIFICATION
Rated voltage: AC600V/DC3KV
Allowable current: 140A
Temperature range: ‐60 ° C ~ +200 ° C
Model: 10AWG 6 mm2
Inner core material: 0.08mm (diameter) tinned copper wire
Insulation material: silica gel
SHIPPING LIST
High Temperature Resistant Silicone Wire (10AWG 6mm2 Red 1m) x1
High Temperature Resistant Silicone Wire (10AWG 6mm2 Black 1m) x1
https://www.dfrobot.com/product‐1757.html 8‐7‐18
很抱歉,暂时无法提供与“FIT0581”相匹配的价格&库存,您可以联系我们找货
