FIT0601
FIT0601
    DFROBOT
    电池
    MONOCRYSTALLINE SOLAR PANEL (5V
FIT0601 数据手册
  Monocrystalline Solar Panel (5V 1A) SKU:FIT0601 INTRODUCTION This is a high-performance, lightweight, portable monocrystalline silicon solar panel in a PET package, with an integrated voltage regulator output of 5V, with working indicators, USB type-A mother-port output, plug-and-play. It can supply plenty of power in various environments to prevent the system from shutting down, even in rainy days. The energy of solar panel will be particularly efficient when paired with the DFRobot solar power management board. The panels are provided with open holes and copper clasps so that they can be attached directly to the backpack for easy portability and use. The ultra-thin, lightweight design weighs just 90g. It's much lighter than a solar panel in a traditional glass package. When you hang this panel, make sure the panel is facing the sun and there is no shade covering the solar panel. SPECIFICATION          Operating Voltage: 5V (With voltage regulator module) Open‐circuit Voltage: 7.2V  Operating Current: 1A(MAX)  Short circuit current: 1.1A  Maximum power: 6W  Material: Monocrystalline Silicon Flexible Lamination  Wire length: 1m  Product size: 27.5cm*16cm*0.2cm / 10.82*6.3*0.078 in  Working temperature: ‐30Ԩ~70Ԩ        https://www.dfrobot.com/product‐1774.html 9‐11‐18
FIT0601 价格&库存
很抱歉,暂时无法提供与“FIT0601”相匹配的价格&库存,您可以联系我们找货
FIT0601
    • 1+97.716151+12.64220
