FIT0618
FIT0618
    DFROBOT
    5V 20 W AC/DC 外部 壁装(II 类) 适配器 固定插片 输入
FIT0618 数据手册
      5V@4A USB Power Adapter (US Standard) SKU:FIT0618 INTRODUCTION When building up a project that motors or servos are needed, the common USB 5V usually cannot supply enough power for the devices, and the potential overheat issue may even occur due to high voltage power supply. But now, with our specially designed power adapter, all the problems gone. This is a power adapter with steady 5V output voltage and 4000mA output current, perfectly compatible with Arduino main controller. The adapter can not only provide suitable power for your projects, but also avoid overheat problem. It can be used as supply power for Raspberry Pi, Arduino controllers, high power LED strip, motor and so on. SPECIFICATION  Input Voltage: 100-240V AC  Output Voltage: 5V  Output Current: 4A SHIPPING LIST  Power Adapter-5V 4A x1  DC2.1 to USB Connector x1        https://www.dfrobot.com/product‐1849.html?search=FIT0618/5‐9‐19
FIT0618 价格&库存
很抱歉,暂时无法提供与“FIT0618”相匹配的价格&库存,您可以联系我们找货
