FIT0631
FIT0631
    DFROBOT
    箱 金属 - 铝 黑色 手持,分叉式双侧 4.530" 长 x 3.070" 宽(115.06mm x 77.98mm) X 0.710"(18.03mm)
FIT0631 数据手册
Aluminum Alloy Passive Cooling Case for LattePanda Alpha SKU:FIT0631 INTRODUCTION Note: Please remove the pre-installed cooling fan on LattePanda Alpha when using the Aluminum Alloy Case. For your safety, please do NOT touch the case directly during use to prevent burns. This aluminum alloy heat sink is designed for LattePanda Alpha Edition. While perfectly protecting the motherboard, the case reserves all peripheral interfaces and GPIO of LattePanda, which allows you to DIY projects of all kinds as much as you like. Aluminum alloy case has good thermal conductivity, and can also be accompanied by high-quality Shintsu X2379215CPU silicone grease and copper heatsink to make the heat dissipation effect more remarkable. Four external fan holes are reserved on the housing, so you can conveniently add a fan on it, such as 4010, 4012 fans. (Recommended Fan Dimension: 40 x 40mm with 32 ±0.3mm hole, M3 screws) FEATURES • Passive cooling aluminum alloy case with good heat dissipation • All ports and GPIO reserved, perfect fit for LattePanda Alpha • Four fan holes are reserved in the upper cover; fans with a 400mm side length; the center distance of the holes is 32 mm • With high quality silicone grease and copper heatsink, we provide you with the perfect heat dissipation scheme. • Reinforced aluminum material, lightweight and durable • Easy to install • Ultra-thin design SPECIFICATION • Material: Aluminum Alloy • Size: 11.5x7.8x1.8cm /4.53x3.07x0.71 inch • Compatible with: LattePanda Alpha DOCUMENTS • Installation Guide SHIPPING LIST • Aluminum Alloy Case for LattePanda Board x1 • Copper heatsink (19.92 x 15.27 x 0.9mm/0.78 x 0.6 x 0.03inch) x1 • 1g Thermal grease silicone x1 NOTE: LattePanda Alpha board and fan is not included. http s://www.dfrobot.com/product-1892.html?search=FIT0631&description=true/9-11-19
FIT0631 价格&库存
很抱歉,暂时无法提供与“FIT0631”相匹配的价格&库存,您可以联系我们找货
