FIT0648
FIT0648
    DFROBOT
    缆线组件 2.62'(800.00mm)
FIT0648 数据手册
          4K HDMI to Micro HDMI Cable SKU:FIT0648 INTRODUCTION This is a Micro-HDMI video cable tailored to the Raspberry Pi 4B, supporting 4K HD resolution. There is no delay, no flash, the transmission is stable and precise. Plug and play, easy to connect. A 19-core shield is adopted in this wire to ensure stable transmission of the signal. A gold-plated process is used in the wire end interface which can prevent oxidation effectively and increase the durability. Multiple plug-ins would not affect its function. PVC environmentally friendly exterior makes it strong and soft, antioxidant and corrosion resisting. So, even through multiple bending, as always, remains stable signal transmission. It is not only suitable for Raspberry Pi 4B, but compatible with a wide range of devices such as notebooks, HDTVs, tablets and projectors. SPECIFICATION  Wire length: 80cm  Interface: Micro-HDMI  Color: Black  Interface Material: gold-plated process  Supporting 4K transmission  Compatible with Raspberry Pi 4B, notebooks, HDTVs, tablets and projectors, etc SHIPPING LIST  4K HDMI to Micro HDMI cable (standard–micro interface) x1                                   https://www.dfrobot.com/product‐1968.html?search=FIT0648&description=true/2‐17‐20
FIT0648 价格&库存
很抱歉,暂时无法提供与“FIT0648”相匹配的价格&库存,您可以联系我们找货
