FIT0655
FIT0655
    DFROBOT
    箱 金属 - 铝 黑色 手持,端面板和盖 4.650" 长 x 3.310" 宽(118.11mm x 84.07mm) X 2.720"(69.09mm)
FIT0655 数据手册
    Cooling Case for Jetson Nano SKU:FIT0655 INTRODUCTION Is your NVIDIA Jetson Nano too hot and overheating? Don’t worry, here comes the cooling solution! This cooling case, with a reset switch and a blue backlit power button, is an efficient thermal solution customized for Jetson Nano. It includes two fans, one is pre-installed inside the case, the other is a PWM controllable fan for cooling CPU. The case comes with two antenna holes and a camera holder for installing antenna and official Raspberry camera. Honeycomb vents of the case reduce the heat generated by your device while it is performing neural network training or running machine vision programs. There are four anti-skid rubber pads on the bottom of the case to prevent skidding. We provide you with anti-static tweezers and screwdriver to help you to install easily; besides, we offer you three jumper caps to ensure the normal operation of reset and restart functions. Note: Raspberry Camera and antenna are not included. SPECIFICATION  Dimension: 118*84*69mm/4.65*3.31*2.72”  Material: aluminium SHIPPING LIST  Body Case x1  Speed Controllable Fan x1  Reset Switch with Jumper x1  5V Power Button with Jumper x1  Camera Holder x1  Specification x1 https://www.dfrobot.com/product‐1987.html?search=FIT0655&description=true/3‐16‐20
FIT0655 价格&库存
很抱歉,暂时无法提供与“FIT0655”相匹配的价格&库存,您可以联系我们找货
