Metal Heatsink Case for Raspberry Pi 4
SKU:FIT0675
INTRODUCTION
This metal heatsink case is specially designed for cooling down your Raspberry Pi 4!
Made of aluminum alloy, the case can protect your mainboard from all directions and
provide a good heat dissipation effect. Inside the case, there is a silicon heat sink
closely attached to the Raspberry Pi chip and radiator, by which the heat generated from
Pi board can be transferred to the radiator, and then be blown out through the fan. With
a complete heat dissipation process from inside to outside, this product can bring
double cooling effects and ultimate cooling experience for your Pi mainboard.
Aluminum Alloy
Aluminum alloy material is more conducive to shell heat dissipation.
Accurate hole alignment
The hole position is precisely aligned, and the mainboard will not be damaged by
disassembly.
Easy to assemble and disassemble, the upper and lower covers can be pulled
It can be replaced and installed at will without moving the main board, saving efficiency.
Efficient Heat Dissipation for Pi Chip
The shell is an independent radiator, and the fan supports efficient heat dissipation.
SPECIFICATION
Dimension: 92*64*40mm/3.62*2.52*1.57”
Material: aluminum alloy
Fan voltage: DC 5V
SHIPPING LIST
Metal Heatsink Case for Raspberry Pi 4 x1
Accessories Package x1
https://www.dfrobot.com/product-2081.html/7-1-22
很抱歉,暂时无法提供与“FIT0675”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+93.411691+12.14322
