KIT0003
KIT0003
    DFROBOT
    DFR0198 MCU Arduino IDE 项目套件
KIT0003 数据手册
      EcoDuino - An Auto Plant Kit SKU: KIT0003   Introduction EcoDuino is evolving. Now the EcoDuino has a new enclosure. It is protected from water splashes, so it is safe to use beside your plants. The EcoDuino now sports an Atmega32U4 which eliminiates the requirement of an adapter. And sketches can simply uploaded via Mirco USB just like Arduino Leonado. Another improvment is that the DS18B20 sensor is now driectly supported. EcoDuino is designed by DFRobot to help you grow plants. By using a series of microcontrollers, sensors and actuators, the EcoDuino system can make your efforts to grow plants much easier. In this system, sensors are used to collect data which can show you plant conditions like temperature,humidity,light intensity, etc... If you want, EcoDuino can message you and tell you how your plants are doing through wireless communications. It will also water your plants automatically when they are thirsty, or at a predetermined interval. The cool thing about the EcoDuino is that it is developed based on on Arduino which means you can not only program EcoDuino in Arduino IDE environment but also use any Arduino compatible hardware in your EcoDuino system. Note:The cables packaged with the sensors is not correct,we suggest you use the orange cables attached. Specification                 Board power supply: 6~12V DC Bootloader: leonardo 4 Analog I/O ports, 5 Digital I/O ports Terminal for interfacing a Carbon rod(Soil moisture sensor) Terminal for interfacing a DS18B20 temperature sensor(Soil temperature sensor) Terminal for interfacing a motor or a solenoid valve Potentiometer to set the threshold soil moisture value of watering Xbee slot Mirco USB 3.5mm screw terminal Board dimensions: 75 x 50 mm Diving pump power supply: 4.5~12V DC Pumping head: 200cm Flow capacity: 100-350L/H Power range: 0.5W-5W Pump dimensions: 38x38x29mm Documents    DHT11 Datasheet http://www.dfrobot.com/image/data/KIT0003/DHT11%20datasheet.pdf Schematic http://www.dfrobot.com/image/data/KIT0003/NEW/Free%20Life%20V1.0%20sch.pdf DHT11 library http://www.dfrobot.com.cn/image/data/DFR0067/dht11.zip Please install the libraries before you testing the sample codes Diagram This kit does not contain carbon, XBEE, DS18B20.  Overall diagram       tip: Soil moisture sensor:blue wire(A2),red wire(VCC),black wire(GND) DHT11 humidity sensor:green wire(D9),red wire(VCC),black wire(GND) Pump:brown wire(+),blue wire(-) Battery holder:red wire(+),black wire(-) The blue potentiometer is connected to the A1 pin of the main control board,The user can read the value and set the threshold for automatic watering. Sensors wiki    Soil moisture sensor DHT11 humidity sensor DS18B20 temperature sensor Sample code Read the sensor value #include dht11 DHT; #define MOISTURE_PIN A2 /soil Moisture sensor/ #define DHT11_PIN //DHT11 int airHumidity; 9 //environment humidity int airTemperature; int soilHumidity; // environment temperature //soil moisture void setup(){ Serial.begin(9600); } void loop(){ int chk; chk = DHT.read(DHT11_PIN); //Read Data switch (chk){ case DHTLIB_OK: Serial.print("OK,\t"); break; case DHTLIB_ERROR_CHECKSUM: Serial.print("Checksum error,\t"); break; case DHTLIB_ERROR_TIMEOUT: Serial.print("Time out error,\t"); break; default: Serial.print("Unknown error,\t"); break; } airHumidity=DHT.humidity; airTemperature=DHT.temperature; soilHumidity=analogRead(MOISTURE_PIN); Serial.print("airHumidity:"); Serial.print(airHumidity); Serial.print(",\t"); Serial.print("airTemperature:"); Serial.print(airTemperature); Serial.print(",\t"); Serial.print("soilHumidity:"); Serial.println(soilHumidity); delay(1000); } Result Open the Serial monitor, Baud rate: 9600. Test the pump void setup() { pinMode(5, OUTPUT); pinMode(6, OUTPUT); digitalWrite(5, LOW); digitalWrite(6, LOW); } void loop() { pumpOn(); delay(1000); pumpOff(); delay(1000); } //open pump void pumpOn() { digitalWrite(5, HIGH); digitalWrite(6, HIGH); } //close pump void pumpOff() { digitalWrite(5, LOW); digitalWrite(6, LOW); } Example of auto flower watering Note: This sample program does not use DHT11. You can set the threshold to turn ON/OFF the pump. When the soil moisture is lower than the threshold, it will turn ON the pump. #define MOISTURE_PIN A2 int soilHumidity; int setHumidity = 50; //Set the pump trigger threshold void setup() { pinMode(5, OUTPUT); pinMode(6, OUTPUT); digitalWrite(5, LOW); digitalWrite(6, LOW); } void loop() { soilHumidity = map(analogRead(MOISTURE_PIN), 0, 1023, 0, 100); 00% soil moisture value //Map analog value to 0~1 if (soilHumidity < setHumidity) { pumpOn(); } else { pumpOff(); } } //open pump void pumpOn() { digitalWrite(5, HIGH); digitalWrite(6, HIGH); } //close pump void pumpOff() { digitalWrite(5, LOW); digitalWrite(6, LOW); }          https://www.dfrobot.com/wiki/index.php/EcoDuino_‐_An_Auto_Plant_Kit_SKU:_KIT0003/‐15‐19
KIT0003 价格&库存
很抱歉,暂时无法提供与“KIT0003”相匹配的价格&库存,您可以联系我们找货
