KIT0119
KIT0119
    DFROBOT
    GRAVITY: SENSOR KIT FOR INTEL JO
KIT0119 数据手册
      Gravity: Sensor Kit for Intel Joule SKU:KIT0119 INTRODUCTION Gravity Sensor Kit for Intel Joule is a plug & play electronics tool kit which gives inventors and IoT developers a quicker and easier experience of prototyping and productizing concepts with the Intel® JouleTM Module. The Intel® JouleTM Module is a Linux-based SoM (System on a Module) which combines a 64-bit, Quad-Core compute engine with power management services, wireless connectivity, high speed I/O and Intel® RealSense™ compatibility powered by Intel® HD Graphics. To make The Intel® JouleTM Module compatible with more modules and easier to use, we have included the Gravity expansion shield in the kit, which adds following supports to its original carrier board: analog input support, 3.3V / 5V switchable power voltage, standard extended connecters (DFRobot Gravity Series sensors and modules compatible). 14 well-chosen DFRobot Gravity electronic modules inside the package cover IoT scenarios including temperature sensing, motion detecting, gesturing recognizing, power control, etc.. With wireless connectivity supported by Intel® JouleTM Module, all the data is accessible from anywhere around the world. NOTE: Joule compute module and expansion board are NOT included Check sensors for arduino if you are interested in arduino, and check sensor kit to get more. FEATURES  Plug&play electronics toolkit for Intel® Joule™  Powered by Intel® Joule™ , a 64-bit, Quad-Core compute module , featuring power management services, wireless connectivity , high speed I/O and Intel® RealSense™ compatibility  14 well-chosen DFRobot Gravity electronic modules with expansion shield; Supports 200+Gravity sensors and actuators  High quality tool box with adjustable grids for neat storing SPECIFICATION  Gravity expansion shield:  Digital I/O: 8  PWM: 4  Analog I/O: 8 (using onboard chip via I2C)  SPI: 1 (with 3 chip select pins)  I2C: 3  UART: 3  Power Output: 5V & 3.3V & 1.8V  Gravity I2C: 1  Gravity UART: 1  Module Voltage: 5V or 3.3V  Gravity Sensor Kit for Intel Joule:  Dimension: 220mm * 165mm * 65 mm/ 86.6 * 65 * 25.6 inches  Weight: 494g SHIPPING LIST  Gravity: IO Expansion Shield for Intel Joule x1  Analog Ambient Light Sensor x1  Digital Push Button x1  Analog Rotation Sensor V2 x1  Digital Buzzer Module x1  LM35 Analog Linear Temperature Sensor x1  Digital Red LED Light Module  Relay Module x1  9g micro servo (1.6kg)  Flame sensor x1 x1 x1  Analog Capacitive Soil Moisture Sensor SEN0193 x1  PIR(Motion)Sensor v1.0 x1  Analog Sound Sensor x1  Digital Capacitive Touch Sensor x1  Triple Axis Accelerometer MMA7361 x1  Flat Noodle Micro USB Cable 1.2M x1  Gravity Digital&Analog Sensor Cable x14 https://www.dfrobot.com/product-1561.html 5-30-17
KIT0119
物料型号: - 重力感应传感器套件,适用于Intel Joule,型号为KIT0119。
器件简介: - 重力感应传感器套件是一个即插即用的电子工具包,为发明家和物联网开发者提供了使用Intel® Joule™模块进行原型设计和产品化概念的快速、简便体验。
引脚分配: - 重力扩展板: - 数字I/O:8个 - PWM(脉冲宽度调制):4个 - 模拟I/O:8个(通过I2C芯片) - SPI(串行外设接口):1个(带3个片选引脚) - I2C:3个 - UART(通用异步接收/发送器):3个 - 电源输出:5V、3.3V、1.8V - Gravity I2C:1个 - Gravity UART:1个 - 模块电压:5V或3.3V
参数特性: - 包括Gravity扩展板和14个精选的DFRobot Gravity电子模块,支持200多个Gravity传感器和执行器。
功能详解: - Intel® Joule™模块基于Linux的SoM(系统级模块),结合了64位四核计算引擎、电源管理服务、无线连接、高速I/O和由Intel® HD Graphics支持的Intel® RealSense™兼容性。
应用信息: - 套件内包括14个精心挑选的DFRobot Gravity电子模块,涵盖物联网场景,包括温度感应、运动检测、手势识别、电源控制等,支持无线连接,数据可从世界各地访问。
封装信息: - 尺寸:220mm 165mm 65 mm / 86.6 65 25.6 英寸 - 重量:494g
注意:Joule计算模块和扩展板不包括在内。
KIT0119 价格&库存
很抱歉,暂时无法提供与“KIT0119”相匹配的价格&库存,您可以联系我们找货
