MBT0009
MBT0009
    DFROBOT
    试验板 Protoboard micro:bit 平台评估扩展板
MBT0009 数据手册
  micro: Breadboard SKU:MBT0009 INTRODUCTION Micro:breadboard is a micro:bit-based expansion board specially designed for STEM-starter. It comes with a 3.23*2.17” breadboard (independent packing, you need to stick them together), on which you can directly build circuit with all sorts of electronic components. All IO ports are led out in the form of pin header and female header, no welding required, plug and play. The electronic parts can be used repeatedly, which greatly reduces the circuit building time. The board has on-board AB buttons, PWR indicator, and independent power switch, more ways to play, meanwhile, much easier to use. This micro:breadboard is especially suitable for building and debugging circuits. It also can be applied to the micro:bit-based applications like, light control lamp, smart doorbell, temperature alarm etc. FEATURES  Free from soldering, electronic components can be used repeatedly  IO ports are led out in the form of pin header and female header, easy to use;  Support visual programming, mind+ and python  Micro USB 5V power interface SPECIFICATION  Operating Voltage: 3.3~5V  Digital Output Voltage: 0V/3.3V  Analog Output Voltage: 0~3.3V DC  Pin Header and Female Header Interface  micro:bit Interface ×19 (P0 P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 P14 P15 P16 P19 P20)  Power Interface ×4  GND Port ×4  3.23 * 2.17” Breadboard (middle size) ×1  PWR Indicator ×1  Power Switch ×1  On-board Button(A/B) ×2  Dimension: 16.2cm×7.2cm/6.38×2.83”  Mounting Hole Size: M3 Screw hole SHIPPING LIST  Micro:bit Breadboard x1  Middle Size Breadboard x1 https://www.dfrobot.com/product‐1865.html?search=MBT0009/7‐12‐19
MBT0009
物料型号:MBT0009
器件简介:micro: Breadboard是一款基于micro:bit的扩展板,专为STEM初学者设计。它包含一个3.232.17英寸的面包板,可以直接在上面搭建电路,无需焊接,即插即用。
引脚分配:所有IO端口以针排和母排的形式引出,支持19个micro:bit接口,4个电源接口,4个GND端口。
参数特性:工作电压3.3~5V,数字输出电压0V/3.3V,模拟输出电压0~3.3V DC。
功能详解:支持可视化编程,Mind+和Python编程,具有micro USB 5V电源接口,板上有AB按钮、PWR指示灯和独立电源开关。
应用信息:适合构建和调试电路,可应用于基于micro:bit的多种应用,如灯光控制、智能门铃、温度报警等。
封装信息:尺寸为16.2cm×7.2cm,安装孔尺寸为M3螺丝孔。
MBT0009 价格&库存
很抱歉,暂时无法提供与“MBT0009”相匹配的价格&库存,您可以联系我们找货
MBT0009
    • 1+120.24858
    库存:147
