ROB0050
ROB0050
    DFROBOT
    4WD MINIQ ARDUINO ROBOT V2.0
ROB0050 数据手册
  4WD MiniQ Complete Kit (SKU:ROB0050)      4WD MiniQ Complete Kit V2 (SKU:ROB0050) 4WD MiniQ Complete Kit V1 (SKU:ROB0050) Introduction 4WD MiniQ mobile robot is especially designed for learning purpose. It comes fully assembled and all your need is a PC with Arduino IDE and 4xAA battery. This upgraded version of MiniQ 4WD Kit comes with new Arduino Leonardo controller (ATmega32u4)but also integrates such modules as 1 RGB LED, photosensitive diode, 2 infrared trasmitter, 1 infrared receiver, 5 infrared line tracking sensor, two light sensors, 5 buttons and 1 buzzer. MiniQ 4WD offers 8 lessons for beginners ,from entry to hunting the line,obstacle avoidance, remote control. Users can easily grasp through the tutorial.Code Package download,tutorials download. https://github.com/Arduinolibrary/Source/blob/master/Code.rar?raw=true https://github.com/Arduinolibrary/Source/blob/master/Tutorial%20pdf.rar?raw=true         lesson1.Get you to know Your Robot lesson2.Control Buzzer lesson3.Light Direction Indication lesson4.Line_follow lesson5.RGB LED lesson6.Obstacle Avoidance lesson7.Encoder lesson8.IR Remote Control Specification        Controller: Atmega32U4(Arduino Leonardo) Power Supply: 4x AA batteries or Micro-USB Working Voltage: 4.5 to 6V Driving Mode: 4WD Max Speed: 79cm/s Size: 115x110x45mm Weight:400g Layout Introduction 4WD MiniQ Complete Kit (SKU:ROB0050) Function about every component:               Infrared transmitter:transmit the infrared signal, the signal can be used for detecting obstacles Infrared receiver:receive infrared signal, the signal can be used for obstacle avoidance Photosensitive diode:sensitive with the light, so it can help you get some information about the light Button:can be programmed for your idea RGB LED:you can change its color use your code, it can show as an alarm and other things you want USB port:download your code and let your robot talk to your computer Buzzer(passive):be an alarm bell or sing a simple song Controller:runs your code Motor:can be controlled to run forward or backward, so that the car can turn left or right freely Reset button;Reset the robot, the program in the robot will runs again from its initiation Power switch:power switch of the robot Power port:power provided from this port Charge port: if your batteries can be charged, you can charge them from this port thus they can be hold in the car Infrared line-follow sensor: can be used for detecting for white or black lines Pin Mapping  Line follow sensor: A0--IR0 (No.1 count from the left) A1--IR1 (No.2 count from the left) A2--IR2 (in middle) A3--IR3 (No.2 count from the right) A4--IR4 (No.1 count from the right)  Follow light: A5  Motors D5-- PWM control from left motor, D12--EN1 direction control from left motor D6-- PWM control from right motor, D7--EN2 direction control from right motor  RGB LED : D10  Infrared obstacle avoidance: Transmitter:D13—IRL left transmitter sensor, D8—IRR right transmitter sensor Receiver: D17—IRS receiver sensor  Button:A6  Encoder: D0--INT2 Right Motor D1--INT3 Left Motor  Buzzer D16(MOSI)— Buzzer https://www.dfrobot.com/wiki/index.php/4WD_MiniQ_Complete_Kit_(SKU:ROB0050) 5-31-17
ROB0050 价格&库存
很抱歉,暂时无法提供与“ROB0050”相匹配的价格&库存,您可以联系我们找货
