Black Gladiator-Tracked Chassis
SKU:ROB0153
If you are gonna build a robotics project, then you need to check out this guy, Black Gladiator.
He is an agile tracked robot chassis, low noise, and easy to control, which could be a good
partner for your any tank-liked robots. This tracked chassis employs high-strength aluminium
alloy base with delicate appearance, higher stability and longer durability.
The track is made of engineering plastic that basically assured the good elasticity,
excellent damping effect and large road grip of the product. What’ s more, it comes with
two quality motors to provide high power and speed, which enables your DIY robot car
to widely suit all kinds of road surfaces.
To explore more possibilities, you can use this tracked chassis with Arduino
microcontrollers or add other electronic components on the base such as, IR sensor,
ultrasonic sensor, camera, LED, display, WIFI module, etc. For Arduino fans and smart
robot car lovers, this is a good choice for you!
Note: the tracked chassis is unassembled, you need to get it done by yourself.
“Black Gladiator”Tracked Chassis Installation tutorial
Step 1: Install the load-bearing wheel (first install the M4*50 long screw into the loadbearing wheel), and lock the other side with the M4 screw.
Step2: place the gasket on the bracket and insert the load-bearing wheel into the hole of
the bracket; the other end is also fitted with a gasket, which is also locked with the M4
nut. Be careful not to screw the load-bearing wheel too tightly.
Step 3: Insert the motor into the bracket and tighten it with 3 M3*6 flat head screws.
Step 4:Install the drive wheel: firstly insert the coupling into the drive wheel, and at the
other end, use the allen key to fit the M3*8 hex socket screw into the drive wheel and
lock it with the coupling.
Step 5:Install the drive wheel on the motor and tighten with black screw; please note:
the hole on the coupling must be aligned with the flat end of the motor shaft.
Step 6: Remove the track first, remove the excess part of the track, and measure the
required track length.
Embed the track pin into the track with a pair of pincers
SPECIFICATION
Assembled Dimensions: 19.3*16.3*6cm(L*W*H)/7.60*6.42*2.36”
Net Weight: 0.47kg
Base Material: aluminium alloy 2mm
Surface Treatment: sandblasting oxidation
Track: engineering plastic
Wheel: plastic
Package Includes: •Base: 1
•Motor: 2
•Track: 2
•Bearing Wheel: 2
•Drive Wheel: 2
•Screw Accessory: 1 set
•Hex Wrench
•Battery Holder: 1
Motor parameter
•Voltage Range: 6V-12V
•No-load Speed: 170-350RPM
•Nominal Voltage: DC 12V
•No-load Current: 100mA
•Weight: 100g
SHIPPING LIST
Black Gladiator-Tracked Chassis x1
https://www.dfrobot.com/product‐1861.html /6‐10‐19
很抱歉,暂时无法提供与“ROB0153”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+192.974041+25.08600
- 国内价格 香港价格
- 1+220.505541+28.66501
