URM06‐ANALOG Ultrasonic SKU:SEN0152
Introduction
Ultrasonic sensors emit ultrasonic pulses, and by measuring the time of ultrasonic pulse reaches the
object and back to the transducer, the distance of sensor from the target object is calculated. They
are widely used in detecting displacement, thickness, distance, water level, material level and
transparent objects.
The URM06 - Analog Ultrasonic sensor provides very short to long-range detection and ranging from
20cm ~ 10m, comes in a compact, robust PVC housing and matches 35mm electrical pipe mounting.
It comes with analog interface and works at high output acoustic power. The ultrasonic sensor
detects objects from 20cm to 1000cm and provides range information with 1cm resolution. The
URM06 has 15 degree beam angle which has excellent receive sensitivity. And it works best when
detecting soft targets. The similar sensors are widely used in professional mobile robot systems such
as Pioneer robots.
The URM06 series sensors are the best ultrasonic sensor available in the market regarding its beam
angle, senstivity and accuracy.
Specification
Working Voltage: 6V-12V (5V is acceptable but not recommended)
Rated Current: 16mA
Peek Current: 2A
Interface: Analog
Working Frequency: 49.5KHZ
Working Temperature: -10 ~ +70
Detecting Angle: 15°(-6dB)
Detecting Range: 20cm ~ 10m
Mounting Thread Diameter: 35mm
Weight: 45g
Applications
robot navigation
obstacle avoidance
measuring distance devices
engineering measurement tools
industrial control system
Connection Diagram
Connection Diagram
Pin Definition
VCC: 6~12V@Max 2A (5V is acceptable but not recommended)
GND: Ground
Trig: Measurement trigger pin - Low level pulse over 50us triggers one distance measurement.
Holding this pin LOW will repeats the measurement every 100ms.
OUT: Analog output pin – 0.33mV stands for 1mm.
Sample Code
#include "Arduino.h"
nce measurement.
#define
TRIGGER
2
OUT: analog output 0.33mV equals 1mm
#define
ANALOG
1
void setup()
pinMode(TRIGGER, OUTPUT);
digitalWrite(TRIGGER, HIGH);
Serial.begin(9600);
void loop()
// generate the pulse to trigger the sensor
digitalWrite(TRIGGER, LOW);
delayMicroseconds(50);
unsigned int distance = analogRead(ANALOG);
//read the analog pin
distance = (unsigned int)(((unsigned long)distance * 5000)/1024);
from analog value to voltage
//change
distance = (unsigned int)((float)distance / 0.33f); //0.33mV equals 1mm
Serial.print("distance:");
Serial.print(distance);
Serial.println("mm");
delay(500);
https://www.dfrobot.com/wiki/index.php/URM06-ANALOG_Ultrasonic_SKU:SEN0152 6-7-17
很抱歉,暂时无法提供与“SEN0152”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+438.814801+56.75069
