SEN0201
SEN0201
    DFROBOT
    LEDDAR M16 SENSOR MODULE (95 DEG
SEN0201 数据手册
Leddar M16 Sensor Module (95 degree beam) SKU:SEN0201 The Leddar M16 Sensor Module is an advanced sensing solution that combines 16 independent active elements into a single sensor, resulting in rapid, continuous and accurate detection and ranging―including lateral discrimination―in the entire wide beam, without any moving parts. The versatile Leddar M16 module can be easily integrated to add cost-effective, smart sensing capabilities to almost any application, enabling developers and integrators to make the most of this cutting-edge technology. Various beam options, creating different fields of view ranging from 9 to 95 degrees, are available to provide the best possible match to your requirements. The modules come with the Leddar Enabler SDK, which provides a user-friendly application programming interface (API) with .Net and C libraries, complete with code examples. Sample code for RS-485/MODBUS for both Windows and Linux, as well as LabVIEW and MATLAB integration examples are also provided. Benefits:       Proven reliability, even in harsh conditions Immune to ambient light No moving parts, for ultimate robustness Easy to integrate, includes Leddar Enabler SDK Low power consumption Best cost/performance ratio FEATURES     16 independent segments with simultaneous acquisition and lateral discrimination capabilities 9o to 95o beam options, for optimized field of view 0 to 100 meter detection range (325 ft.) Rapid data acquisition time, up to 50 Hz SPECIFICATION                Beams: 95 degree Detection range: 0 to 100 meters (325 ft.) Accuracy: 5 cm Data refresh rate: 6.25 Hz to 100 Hz Operating temperature range: -40C to + 85C Meets IEC 62471 2006 criteria: Exempt lamp classification Distance precision: 6 mm Distance resolution: 10 mm Power consumption: 4 W Interfaces: USB, RS-485, CAN, UART Wavelength: 940 nm Power supply: 12 or 24 VDC (jumper - selectable) Dimensions: 104 x 66 x 48 (mm)/ 4.09 x 2.6 x 1.89 (inches) Weight: 180 g SHIPPING LIST   Leddar M16 Sensor Module (95 degree beam) x1        https://www.dfrobot.com/product‐1411.html 8‐23‐18
SEN0201 价格&库存
很抱歉,暂时无法提供与“SEN0201”相匹配的价格&库存,您可以联系我们找货
