Gravity: I2C VEML7700 Ambient Light
Sensor SKU: SEN0228
Introduction
VEML7700 is a high accuracy ambient light digital 16-bit resolution sensor. It includes a high
sensitive photo diode, a low noise amplifier, a 16-bit A/D converter and supports an easy to use
Gravity I2C interface. It outputs a digital signal directly and no need for complicated calculations.
This is a more acurate and easier to use version of the simple foto resistor which only outputs a
voltage that needs to be calculated in order to obtain meaningful data. The data which is output by
this sensor is directly output in Lux (Lx). When objects which are lighted in homogeneous get the 1 lx
luminous flux in one square meter ,their light intensity is 1lx. Sometimes to take good advantage of
the illuminant, you can add a reflector to the illuminant. So that there will be more luminous flux in
some directions and it can increase the ilumination of the target surface.
For example:
Night: 0.001--0.02;
Moonlightnight:0.02--0.3;
Cloudy indoor:5--50;
Cloudy outdoor:50--500;
Sunny indoor:100--1000;
Under the sunlight in summer afternoon: about 10*6 power;
Reading books for intensity of illumination:50--60;
Home video standard intensity of illumination:1400.
Specification
Supply Voltage: 3.3-5V
Working Current: 45uA
Shutdown Mode: 0.5uA
Measuring Range: 0-120klx
Accuracy: 0.0036 lx / ct
Working Temperature: -25 ~ +85
Dimension: 30 × 22 (mm) /1.81 x0.866 (inches)
Weight: 12g
Board Overview
Gravity: I2C VEML7700 Ambient Light Sensor
Num
Label
Description
1
SDA
IIC-Data
2
SCL
IIC-Clock
3
GND
GND
4
VCC
VCC
Tutorial
Requirements
Hardware
DFRduino UNO (or similar) x 1
Gravity: I2C VEML7700 Ambient Light Sensor x1
M-M/F-M/F-F Jumper wires
Software
Arduino IDE, Click to Download Arduino IDE from Arduino®
https://www.arduino.cc/en/Main/Software%7C
Connection Diagram
Arduino Connection
Sample Code
Download VEML7700 Arduino Library https://github.com/DFRobot/DFRobot_VEML7700
How to install Libraries in Arduino IDE https://www.arduino.cc/en/Guide/Libraries#.UxU8mdzF9H0%7C
* @file readVEML770.ino
* @brief DFRobot's Digital Ambient Light Sensor
* @n This example read the Lux from Digital Ambient Light Sensor, and then p
rint them
* @copyright
[DFRobot](http://www.dfrobot.com), 2016
* @copyright
GNU Lesser General Public License
* @version
* @date
V1.0
2016-12-06
#include
#include "DFRobot_VEML7700.h"
DFRobot_VEML7700 als;
void setup()
Serial.begin(9600);
als.begin();
void loop()
float lux;
Serial.print("Lux: ");//Read Lux and print
Serial.print(lux);
Serial.println(" lx");
delay(500);
Expected Results
Result
https://www.dfrobot.com/wiki/index.php/Gravity:_I2C_VEML7700_Ambient_Light_Sensor_SKU:_SEN0228 9‐19‐17
很抱歉,暂时无法提供与“SEN0228”相匹配的价格&库存,您可以联系我们找货
