Gravity: Analog Sound Level Meter
SKU:SEN0232
Introduction
Analog Sound Level Meter SKU:SEN0232
In our environment, there are all kinds of sounds, some of which are noise. With the development of
human civilization, the quiet environments are less and less, but more and more noisy environments
instead. Staying in the noise for long time will have an impact on hearing, which is bad for health.
Sound level meter (also known as the decibel meter, noise meter) is a basic noise measurement
instrument.We have launched a sound level meter, which is compatible with Arduino, plug-and-play .
It can accurately measure the sound level of the surrounding environment. This product uses
instrument circuit, low noise microphone, which makes it highly precious. It supports 3.3~5.0V wide
input voltage, 0.6~2.6V voltage output. The decibel value is linear with the output voltage, which
leads to a simple conversion, without complex algorithm.The connector is plug-and-play, without
welding, so this product can be easily used in your application.
Sound level meter is widely used in environmental noise detection, such as highway noise
monitoring station, room noise monitoring and so on. It’s time for you to DIY a sound level detector
to protect your hearing.
The black film on the microphone is a sensitive component, do not touch it with fingernails or
other sharp objects.
Do not place this module on the surface of the conductor or the semiconductor, otherwise it
will short the microphone’s pins. It is recommended to place this module on a dry insulator’s
surface or secure with nylon columns to hang in the air.
Specification
Measuring Range: 30dBA ~ 130dBA
Measurement Error: ±1.5dB
Frequency Weighted: A Weighted
Frequency Response: 31.5Hz ~ 8.5KHz
Time Characteristics: 125ms
Input Voltage: 3.3 ~ 5.0V
Input Current: 22mA@3.3V, 14mA@5.0V
Output Voltage: 0.6 ~ 2.6V
Module Size: 60mm * 43mm
Board Overview
Num Label
Sound Level Meter
Description
1
A
Analog Signal Output(0.6~2.6V)
2
Power VCC(3.3~5.0V)
3
Power GND(0V)
Tutorial
This tutorial will show you how to use this module to measure the decibel value of surrounding
environment.
Requirements
Hardware
DFRduino UNO (or similar) x 1
Sound Level Meter x1
Gravity 3P Cable (or dupont Line) x 1
Software
Arduino IDE (Version requirements: V1.0.x or V1.8.x), Click to Download Arduino IDE from Arduino®
Connection Diagram
Sample Code
DFRobot Gravity: Analog Sound Level Meter
This sample code is used to test the analog sound level meter.
Created 2017-06-26
By Jason
GNU Lesser General Public License.
See for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1. This sample code is tested on Arduino Uno with Arduino IDE 1.0.5 r2.
2. In order to protect the microphone on the board, you should not touch the
black membrane on the microphone. Also you should keep it clean.
3. Please do not place this module on the surface of conductor or semicondu
ctor. Otherwise, this will cause the microphone pin to be shorted.
#define SoundSensorPin A1
level meter
#define VREF
5.0
//voltage on AREF pin,default:operating voltage
void setup()
Serial.begin(115200);
void loop()
//this pin read the analog voltage from the sound
float voltageValue,dbValue;
voltageValue = analogRead(SoundSensorPin) / 1024.0 * VREF;
dbValue = voltageValue * 50.0;
//convert voltage to decibel value
Serial.print(dbValue,1);
Serial.println(" dBA");
delay(125);
Expected Results
After uploading the sample code, you can open the serial monitor, and get the decibel value. The
test environment is the office.The decibel value is shown as below.
Relation between Decibel Value and Voltage Output
For this product,the decibel value is linear with the output voltage.When the output voltage is 0.6V,
the decibel value should be 30dBA. When the output voltage is 2.6V, the decibel value should be
130dBA.
The calibration is done before leaving the factory, so you don't need to calibrate it.
So we can get this relation: Decibel Value(dBA) = Output Voltage(V) × 50, as shown below.
For any questions, advice or cool ideas to share, please visit the DFRobot Forum.
More Documents
Analog Sound Level Meter Layout
https://www.dfrobot.com/wiki/index.php/Gravity:_Analog_Sound_Level_Meter_SKU:SEN0232 1-10-18
很抱歉,暂时无法提供与“SEN0232”相匹配的价格&库存,您可以联系我们找货
