Pixy 2 CMUcam5 Image Sensor (Robot Vision)
SKU:SEN0265
INTRODUCTION
Pixy2 is smaller, faster and more capable than the original Pixy. Like its predecessor,
Pixy2 can learn to detect objects that you teach it, just by pressing a button.
Additionally, Pixy2 has new algorithms that detect and track lines for use with linefollowing robots. The new algorithms can detect intersections and “road signs” as well.
The road signs can tell your robot what to do, such as turn left, turn right, slow down,
etc. And Pixy2 does all of this at 60 frames-per-second, so your robot can be fast, too.
Connect directly to Arduino or Raspberry Pi
No need to futz around with tiny wires — Pixy2 comes with a special cable to plug directly into an
Arduino and a USB cable to plug into a Raspberry Pi, so you can get started quickly. No Arduino or
Raspberry Pi? No problem! Pixy2 has several interfaces (SPI, I2C, UART, and USB) and simple
communications, so you get your chosen controller talking to Pixy2 in short order.
Simplify your programming
To get you up and running as fast as possible, we offer software libraries for Arduino and Raspberry Pi.
Pixy2 makes your programs simpler by only sending the data you’re looking for. For example, if you
teach Pixy2 a purple object, you will only receive data (X‐Y coordinates, size, and unique ID) about the
purple objects that Pixy2 detects.
FEATURES
Pixy2 detects lines, intersections and small barcodes, intended for line‐following robots
Improved framerate – 60 frames‐per‐second
Tracking algorithms have been added to color‐based object detection
Improved and simplified libraries for Arduino, Raspberry Pi and other controllers
Integrated light source
SPECIFICATION
Lens type: Standard M12
Processor: NXP LPC4330, 204 MHz, dual core
Image sensor: Aptina MT9M114, 1296×976 resolution with integrated image flow processor
Lens field‐of‐view: 60 degrees horizontal, 40 degrees vertical
Power consumption: 140 mA typical
Power input: USB input (5V) or unregulated input (6V to 10V)
RAM: 264K bytes
Flash: 2M bytes
Available data outputs: UART serial, SPI, I2C, USB, digital, analog
Dimensions:1.5” x 1.65” x 0.6”
Weight: 10 grams
Integrated light source, approximately 20 lumens
SHIPPING LIST
Pixy 2 CMUcam5 Image Sensor x1
FC‐10P to FC‐6P Cable x1
Screw Package x1
https://www.dfrobot.com/product‐1752.html 8‐7‐18
很抱歉,暂时无法提供与“SEN0265”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+677.092241+87.57804
