RP-L-170 Thin Film Pressure Sensor
SKU:SEN0293
INTRODUCTION
This is a long flexible thin film pressure sensor with a length of 170mm, which can be used to
realize highly sensitive detection of pressure. The sensor is durable and designed to sense
static and dynamic pressure in a high respond speed. Its advantages of recording the intensity
and frequency of force make it widely used in all kinds of applications, such as, pressure switch,
bed monitoring system, intelligent sneaker and medical device system. These sensors are also
very easy to use.
RP-L flexible pressure sensor is made of ultra-thin film of excellent mechanical property,
excellent conductive materials and nanometre pressure sensitive layers. There are thin
film and pressure sensitive layer on the upper layer of the sensor, and thin film and
conductive circuit on the lower layer. These two layers are glued together by double
sided tape. When outside pressure applies to the active area, the disconnected circuit of
the lower layer will be connected through the pressure sensitive layer of the upper layer,
by which to convert pressure into resistance. The output resistance decreases as
pressure increases.
RP-L-170 Dimension Diagram
Force vs Resistance
SPECIFICATION
Thickness: 0.35mm
Trigger Force:
很抱歉,暂时无法提供与“SEN0293”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+57.220881+7.42623
