RP-S40-ST Thin Film Pressure Sensor
40mmx40mm
SKU:SEN0296
INTRODUCTION
This is a square flexible thin film pressure sensor of short legs with a side length of 40mm,
which can be used to realize highly sensitive detection of pressure. The sensor is durable and
designed to sense static and dynamic pressure in a high respond speed. Its advantages of
recording the intensity and frequency of force make it widely used in all kinds of applications,
such as, pressure switch, bed monitoring system, intelligent sneaker and medical device
system. These sensors are also very easy to use.
RP-C flexible pressure sensor is made of ultra-thin film of excellent mechanical
property, excellent conductive materials and nanometre pressure sensitive layers.
There are thin film and pressure sensitive layer on the upper layer of the sensor, and
thin film and conductive circuit on the lower layer. These two layers are glued together
by double sided tape. When outside pressure applies to the active area, the
disconnected circuit of the lower layer will be connected through the pressure sensitive
layer of the upper layer, by which to convert pressure into resistance. The output
resistance decreases as pressure increases.
RP-S40-ST Dimension Diagram
Force vs Resistance
SPECIFICATION
Thickness: 0.45mm
Trigger Force: 20g, triggered (default resistance10MΩ
Activation Time: 1million times
Hysteresis: +10%,(RF+ -RF-)/FR+,1000g Force
Response Time:
很抱歉,暂时无法提供与“SEN0296”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.783851+9.02615
