SEN0297
SEN0297
    DFROBOT
    RP-C7.6-ST THIN FILM PRESSURE SE
SEN0297 数据手册
        RP-C7.6-ST Thin Film Pressure Sensor SKU:SEN0297 INTRODUCTION This is a circular flexible thin film pressure sensor of short legs with a diameter of 7.6mm, which can be used to realize highly sensitive detection of pressure. The sensor is durable and designed to sense static and dynamic pressure in a high respond speed. Its advantages of recording the intensity and frequency of force make it widely used in all kinds of applications, such as, pressure switch, bed monitoring system, intelligent sneaker and medical device system. These sensors are also very easy to use. RP-C flexible pressure sensor is made of ultra-thin film of excellent mechanical property, excellent conductive materials and nanometre pressure sensitive layers. There are thin film and pressure sensitive layer on the upper layer of the sensor, and thin film and conductive circuit on the lower layer. These two layers are glued together by double sided tape. When outside pressure applies to the active area, the disconnected circuit of the lower layer will be connected through the pressure sensitive layer of the upper layer, by which to convert pressure into resistance. The output resistance decreases as pressure increases. RP-C7.6-ST Dimension Diagram Force vs Resistance SPECIFICATION  Thickness: 0.3mm  Trigger Force: 30g, triggered (default resistance10MΩ  Activation Time: 1million times  Hysteresis: +10%,(RF+ -RF-)/FR+,1000g Force  Response Time:
SEN0297 价格&库存
很抱歉,暂时无法提供与“SEN0297”相匹配的价格&库存,您可以联系我们找货
SEN0297
    • 1+26.478011+3.42781
    库存:274
