SEN0303
SEN0303
    DFROBOT
    GRAVITY VEML6075 UV SENSOR MODUL
SEN0303 数据手册
    Gravity VEML6075 UV Sensor Module SKU:SEN0303 Introduction This is a UV sensor module based on Vishay VEML6075 sensor, adopting individual UVA and UVB channel solution with 16-bit resolution. It can convert solar UV light intensity to digital data to provide an accurate measure of the signal strength. VEML6075 UV sensor can give a reliable performance of UV radiation measurement under long time solar UV exposure. Furthermore, the sensor provides excellent temperature compensation capability within -40Ԩ to +85Ԩ. VEML6075 features, low power consumption, and its minimum power can be as low as 800nA in shut-down mode. The operating voltage of the sensor ranges from 3.3V to 5V. It adopts IIC protocol, which can work well with any microcontroller that supports IIC. Compatible with Arduino and Raspberry Pi, this sensor can be used in portable electronic product, wearable device, weather station, flame detecting and so on. We have related Arduino and Python library for your reference, and provide you with a Gravity connector to enable you to use the sensor without soldering. Application Ultraviolet tester, outdoor UV detector, bactericidal lamp Specification  Operating Voltage: 3.3V~5V  Operating Current: 700uA  Shut-down Mode: 10uA  UV Chip: VEML6075  Output: digital output  Response Wavelength: UVB (λ0.5) within 315nm to 340nm; UVA (λ0.5) within 350nm to 375nm.  Interface: PH2.0-4P  IIC Address: 0x10  Dimension: 22×30mm/0.87×1.18”  Mount Hole Size: 3mm  Mount Hole Pitch: 15mm  Operating Temperature: -40Ԩ~+85Ԩ NOTE: to get more accurate measurement, the sensor should direct to ultraviolet light source. Pinout Num Label Description 1 SDA Serial Data Line 2 SCL Serial Clock Line 3 GND Ground 4 VCC DC 3.3V~5.5V Tutorial (Arduino) Connect the sensor with Arduino UNO via I2C interface as shown below:  Connect the sensor VCC to power pin(3.3V or 5V) of Arduino microcontroller.  Connect the sensor GND to Arduino GND.  Connect the sensor SCL to I2C SCL pin of Arduino (pin A5 in Arduino UNO&328).  Connect the sensor SDA to I2C SDA pin of Arduino (pin A4 in Arduino UNO&328). Arduino Example Code Click to download DFRobot_VEML6075 Library file, about how to install the library? /*!   *  file VEML6075SimpleTest.ino   *  simple test for VEML6075   *  Print UVA index, UVB index and UV index on the serial monitor   *   *  Copyright    [DFRobot](http://www.dfrobot.com), 2018   *  Copyright    GNU Lesser General Public License   *  version  V1.0   *  date  2018‐12‐18   */    #include   #include     #define VEML6075_ADDR   0x10    DFRobot_VEML6075_IIC VEML6075(&Wire, VEML6075_ADDR);  // create object    void setup()  {    Serial.begin(115200);    delay(2000);    while(!Serial);      Serial.println();    while(VEML6075.begin() != true) {      Serial.println("VEML6075 begin faild");      delay(2000);    }    Serial.println("VEML6075 begin successed");  }    void loop()  {    uint16_t    UvaRaw = VEML6075.readUvaRaw();         // read UVA raw    uint16_t    UvbRaw = VEML6075.readUvbRaw();         // read UVB raw    uint16_t    comp1Raw = VEML6075.readUvComp1Raw();   // read COMP1 raw    uint16_t    comp2Raw = VEML6075.readUvComp2Raw();   // read COMP2 raw      float       Uva = VEML6075.getUva();                // get UVA    float       Uvb = VEML6075.getUvb();                // get UVB    float       Uvi = VEML6075.getUvi(Uva, Uvb);        // get UV index      Serial.println();    Serial.println("======== start print ========");    Serial.print("UVA raw:    ");    Serial.println(UvaRaw);    Serial.print("UVB raw:    ");    Serial.println(UvbRaw);    Serial.print("COMP1 raw:  ");    Serial.println(comp1Raw);    Serial.print("COMP2 raw:  ");    Serial.println(comp2Raw);    Serial.print("UVA:        ");    Serial.println(Uva, 2);    Serial.print("UVB:        ");    Serial.println(Uvb, 2);    Serial.print("UVIndex:    ");    Serial.print(Uvi, 2);    if(Uvi
SEN0303 价格&库存
很抱歉,暂时无法提供与“SEN0303”相匹配的价格&库存,您可以联系我们找货
SEN0303
  • 1+66.416081+8.59055
