Gravity: URM09 Analog Ultrasonic Sensor
SKU:SEN0307
INTRODUCTION
What is an Ultrasonic Sensor?
An Ultrasonic sensor is a device that can measure the distance to an object by using sound
waves. It measures distance by sending out a sound wave at a specific frequency and listening
for that sound wave to bounce back.
Diagram of the basic ultrasonic sensor operation
Since it is known that sound travels through air at about 344 m/s (1129 ft/s), you can
take the time for the sound wave to return and multiply it by 344 meters (or 1129 feet) to
find the total round-trip distance of the sound wave. Round-trip means that the sound
wave traveled 2 times the distance to the object before it was detected by the sensor; it
includes the 'trip' from the sonar sensor to the object AND the 'trip' from the object to the
Ultrasonic sensor (after the sound wave bounced off the object). To find the distance to
the object, simply divide the round-trip distance in half.
DFRobot URM09 is an ultrasonic sensor specially designed for fast ranging and
obstacle avoidance applications. Its measuring frequency can reach up to 30Hz. The
sensor adopts built-in temperature compensation and analog output. Meanwhile, it can
provide accurate distance measurement within 500cm. The sensor is compatible with
Arduino, Raspberry Pi or other main-control boards with 3.3V or 5V logic level.
SPECIFICATION
Power Supply: 3.3~5.5V DC
Operating Current: 20mA
Operating Temperature: -10Ԩ~+70Ԩ
Measurement Range: 2cm~500cm
Resolution: 1cm
Accuracy: 1%
Frequency: 30Hz Max
Dimension: 47mm × 22 mm/1.85× 0.87”
SHIPPING LIST
URM09 Ultrasonic Sensor (Gravity Analog) x1
PH2.0-3P Connector x1
https://www.dfrobot.com/product‐1863.html?search=SEN0307/7‐12‐19
很抱歉,暂时无法提供与“SEN0307”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.528891+8.99198
