SEN0311
SEN0311
    DFROBOT
    超声波 传感器 平台评估扩展板
SEN0311 数据手册
A02YYUW Waterproof Ultrasonic Sensor SKU:SEN0311 INTRODUCTION Ultrasonic distance sensor determines the distance to a target by measuring time lapses between the sending and receiving of the ultrasonic pulse. This is an easy-to-use commercialgrade ultrasonic sensor module of high performance and reliability, featuring much smaller blind zone, wider sensing angle and a certain penetration power(smog, dust) compared with other similar sensors . Connection with Arduino The ultrasonic sensor adopts closed separated probe, waterproof and dustproof, which could be well suitable for harsh and moist measuring environment. All the signal processing units are integrated inside the module, so users can directly obtain the distance value through Asynchronous Serial Interface. With 9600bit/s band rate, the sensor can easily communicate with upper-host or other MCU, which greatly shortens the developing cycle for users. Connection with Raspberry Pi Use the sensor with Arduino controller to build up your projects, such as backing car annunciator, obstacle avoidance robot, object approaching detection etc. Beam Directionalities Diagram Dimension Diagram SPECIFICATION • Operating Voltage: 3.3~5V • Average Current:
SEN0311 价格&库存
很抱歉,暂时无法提供与“SEN0311”相匹配的价格&库存,您可以联系我们找货
