TF03 (ToF) Laser Range Sensor(180m)
SKU:SEN0329
INTRODUCTION
TF03, a long-distance LiDAR in accordance with industrial level, provides detection range up to
180m. As the third generation product of TF series, TF03 inherits the cost-effective and
compact-integration advantages from the previous two generations. Meanwhile, TF03 upgrades
more than ten key parameters and offers multiple expansion functions to meet the various
demands in different application scenarios. With a small size of 44*42.9*31.8mm, it can be
covered by just a palm of one hand. The product is applicable to the terrain following of drones,
the collision avoidance of cars, intelligent transportation, and industrial safety warning.
TF03 employs the pulsed time-of-flight principle. The unique design of the optical
system and the signal processing circuit improved the detecting performance in a
compact size. In addition to increasing the range to more than 100 meters,
this sensor features 0.1m blind zone, ±10cm accuracy, up to 10KHz frequency, and
100Klux ambient light immunity. TF03 also contains a compensation algorithm targeting
outdoor highlight environment, so that it can still keep excellent performance in harsh
environment.
Detection angle schematic
Spot simulated diagrams and sizes at different distances
Note: In it, the red is the strongest, the green is weak, and the dark blue is the
background, and the spot size is the length and width of the green in the figure.
The shell of TF03 is made of aluminum alloy and infrared band-pass glass to improve
the overall strength. With IP67 enclosure rate, the sensor can be applied in various
extreme environments. It supports multiple interfaces for different applications, such as
UART, CAN, IO. Besides that, multiple parameters of TF03 can be configured by
customers, including the measuring frequency, baud rate, trigger mode, over-range
assignment, and so on. TF03 is also equipped with BootLoader function, enabling users
to upgrade product firmware locally. Power the sensor with 5V. The average power
consumption is 0.55W. It is compatible with controllers like Arduino, Raspberry Pi.
With Arduino and Raspberry Pi libraries developed by DFRobot, users can conveniently
integrate functions into the system to develop their applications.
Dimension Diagram
Note
1. This product can only be maintained by qualified professionals and only the original
spare parts can be used to ensure its performance and safety.
2. The product itself has no polarity and over-voltage protection. Please complete wiring
and supply power correctly according to the contents of the Manual.
3. The working temperature of the product is -20℃~60℃, do not use it beyond this
range so as to avoid risks.
4. The storage temperature of the product is -40°C~85°C; please do not store it beyond
this temperature range, so as to avoid risks.
5. Do not open its enclosure for assembly or maintenance beyond this Manual;
otherwise, it will affect the product performance.
6. When the product transmitter and receiver lens are covered by dirt, there will be a
risk of failures. Please keep the lens clean.
7. The product will have a risk of failure when immersed completely in water. Do not use
it underwater.
8. When detecting objects with high reflectivity, such as mirrors and smooth tiles, the
product may have a risk of failures.
SPECIFICATION
Product Performance
Range: 0.1m-180m@90% reflectivity
0.1m-70m@10% reflectivity 0.1m-130m@90% reflectivity &100Klux, 0.1m-50m@10%
Accuracy: ±10cm (less than 10m), 1%(more than 10m)
Distance Resolution: 1cm
Frame Rate: 1Hz-1000Hz Adjustable (Default 100Hz)
Ambient Light Immunity: 100klux
Repeatability: 1σ:
很抱歉,暂时无法提供与“SEN0329”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2651.161081+343.16517
