SEN0503
SEN0503
    DFROBOT
    模块
    光学传感器 穿透光束 19.685"(500mm) NPN 模块
SEN0503 数据手册
IR Break Beam Sensor (50cm) SKU:SEN0503 INTRODUCTION Infrared break-beam sensors are a simple way to detect motion. This IR break beam sensor works up to 50cm with a fast and stable response of <2ms. With a small size of 20*10*9mm, the module can be conveniently installed in a narrow space. Besides, it can operate within a temperature of -25°C to 60°C. Power the sensor by a voltage of DC 3.0~5V. It can be used with Arduino for some simple motion detection, speed detection, timing, etc. in smart robot competitions. They work by having an emitter side that sends out a beam of human-invisible IR light, then a receiver across the way which is sensitive to that same light. When something passes between the two, and it’s not transparent to IR, then the“beam is broken“and the receiver will output a signal to let you know. FEATURES  Fast and stable response speed  Can be conveniently installed in a narrow space APPLICATIONS  Simple motion detection  Speed detection  Timing SPECIFICATION  Induction Distance: 50CM / (5V), 20CM / (3.3V)  Induction Method: through-beam type (non-transparent)  Working Voltage: DC 3.0 V-5V  Working Current: 25mA  Output Mode: NPN normally open  Output Current: 100mA (can directly drive the relay)  Emitting Angle: straight line (infrared light)  Receiving Angle: <10°  Response Time: 2ms  Working Temperature: -25°C ~ 60°C  Working Environment: indoor (not waterproof)  Dimensions: 20*10*9mm (L*W*H)  Cable Length: 25cm / 9.84 inch  Light Hole: 3MM / 0.12 inch  Transmitter: red wire=5V DC, black wire=GND  Receiving: red wire =5V DC, black wire=GND, white wire=OUT (NPN) SHIPPING LIST  IR Break Beam Sensor (50cm) - Receiver x1  IR Break Beam Sensor (50cm) - Transmitter x1 https://www.dfrobot.com/product-2388.html/4-22-22
SEN0503 价格&库存
很抱歉,暂时无法提供与“SEN0503”相匹配的价格&库存,您可以联系我们找货
