SKU:SEN0509
Introduction
This capacitive pipeline liquid level sensor of high sensitivity is suitable for non-metallic pipes
with a diameter of 6mm. The sensor outputs digital high/low level(low when liquid detected) and
adopts 3-pin DuPont connector, which can be widely used in beverage machines, small water
pipe level detection, and infusion pipe level detection scenarios.
Working Principle: The liquid level sensor uses the sensing capacitance of water to detect the
presence of liquid. When there is no liquid approaching the sensor, the sensor has a certain static
capacitance due to the distributed capacitance. When the liquid level slowly rises close to the
inductor, the parasitic capacitance of the liquid will be coupled to the static capacitor, causing the
final capacitance of the inductor to become larger. The changed capacitance signal is then input
to the control IC for signal conversion, which will change. The capacitance is converted into the
amount of change of an electrical signal, and then a certain algorithm detects and judges the
degree of the change. When the amount of change exceeds a certain threshold, the liquid level is
considered to reach the sensing point.
Specification
Working Voltage: 2.5~5.5VDC
Working Current: 5V290uA 3V235uA
Output: low (liquid detected), high level(no liquid detected)
Hysteresis: ±0.25%FS
Interval Medium: plastic
Protection Level: IP62
Operating Temperature: -20~100℃
Weight: 3g
Dimension
Tutorial
Connection Diagram
Sample Code
Click to download Arduino IDE
int ledPin = 13; // LED connected to digital pin 13
int inPin = 7;
// pushbutton connected to digital pin 7
int val = 0;
// variable to store the read value
void setup()
pinMode(ledPin, OUTPUT);
pinMode(inPin, INPUT);
void loop()
val = digitalRead(inPin);
digitalWrite(ledPin, val);
// sets the digital pin 13 as output
// sets the digital pin 7 as input
// read the input pin
// sets the LED to the button's value
Result
If the sensor detects liquid, the onboard LED of UNO will turn off. If no liquid is detected, the
onboard LED of UNO will turn on.
FAQ
For any questions, advice or cool ideas to share, please visit the DFRobot Forum.
https://wiki.dfrobot.com/Capacitive_Pipeline_Liquid_Level_Sensor_SKU_SEN0509/8-3-22
很抱歉,暂时无法提供与“SEN0509”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+88.206481+11.46656
